Results 1 to 7 of 7
    Jul 2018
    155
    Fast backslash!!
    Currently have a back slash with a 2200kv setup on 4s. Revo slipper. I used to run just straight up buggy tires and this thing was fast but since I got Some grp road tires (1/8) the tires are now smaller and they dont balloon so I lost speed.
    I'm already geared at 22/50. How high can I gear this with factory chassis (lcg)? I would run 6s but there's really no room for my 6s pack on this chassis..
    Sent from my SM-G955U using Tapatalk
    Dec 2017
    North Texas
    619
    If you are looking for pure speed, I would look on eBay for a slipper eliminator and put in a revo 34t mod 1 spur.
    Then you should have more room for a larger pinion. I don't recall exactly what size works with the motor in the stock location, but should be enough room to get the car near 100mph
    Jun 2014
    Southern California
    7,540
    You can fit a 31T Mod1 spur. I think the largest pinion that can fit with that in the stock motor location is a 25T Mod1.
    Good luck and have fun!
    Jul 2018
    155
    I bought a 31t pinion to go with the 50t m0.8 spur.
    Is .08 the same as 32p?
    I see traxxas sells some metric pitch 1.0. I could probably use one of these and buy a mod 1 pinion to go with it. If this works? I'd have to figure out gear ratios I'm sure going to a different pitch changes it
    Jul 2018
    155
    Quote Originally Posted by LibertyMKiii View Post
    Can I still run the revo spur without the slipper eliminator?
    Jul 2018
    155
    I meant to quote you.. see above
    Dec 2017
    North Texas
    619
    Quote Originally Posted by jake414 View Post
    Yes you can, and if noise is of any concern the plastic revo spur runs very quiet.
