    Apr 2019
    116
    Motor Fan for Castle Creations 3800kv motor? Will it fit with stock tranny case?
    Hello... I was wondering if there is a motor fan for the 3800 kv motor? If so, will it fit with the stock tranny case? Does it make a huge difference? Thanks.
    Dec 2016
    198
    It helps temps on mine quite a bit
    I have an aluminum Gearbox, so Iím not sure if it will fit stockó-my castle fan covers majority of 3800 motor
    Dec 2003
    Dekalb, IL
    2,407
    You can trim the housing on the castle fan, it's plastic. I have one from my castle 3800kv motor I used to run in my stampede. I trimmed the sides a bit because they were in the way of getting the motor mount screw in place. I later took the castle fan out and put a higher velocity yeah racing fan in.
    This is the 36mm one:
    https://www.amainhobbies.com/castle-...014-00/p191032
    Expert rigging at it's best!
