Results 1 to 17 of 17
    Mar 2016
    471
    anyone running LIPO power in the Teton
    hi anyone running 2S LIPO in there Teton my 12 year old step son already went though 2 stock Teton motors in 3 days & 2 trips to the hobby shop. Not worried about cost of motor since there only 10.00 bucks a piece. The Hobby Shop r/c tech suggested gearing up the truck so the motor don't run as hot on LIPO power but said I should ask on the Teton thread for advice because he's not that experienced in the Teton motor or gearing setups.
    Aug 2019
    15
    I just put a 2s 7.4 volt venom lipo in mine. Fits flat and adds quite a bit of power. I didnít upgrade anything else and havenít had any issues yet, but I plan on upgrading some parts as I imagine theyíll start breaking soon.
    Mar 2018
    25
    I run a 1300Mah 2S in mine - I've had no more problems because of it. Just keep an eye on your temps...
    From Melbourne, Australia.
    Dec 2016
    N Dakota USA
    671
    Like Isear said, watching your temp is key.
    Aug 2019
    37
    Ya watch temps.
    To answer your question about gearing. You could put a smaller pinion in there to help it not get as hot.
    Jan 2019
    23
    Quote Originally Posted by smeezy View Post
    Ya watch temps.
    I've cooked a few motors in my Tenton now running 2s with the stock motor.
    Would changing the gearing mess with the temp of the ESC?
    The motor is cheaper than an ESC.
    I also have a heat sink on the motor, but it will still roast them.
    Maybe a fan set up of some sort?
    389
    Hi mate, if you can hold off a day or two Iíll try dig up some pics of an old Teton build and post a thread.
    The most important thing I found was that the driveline was binding. It took a while to find, but it is caused by the diff casings binding to either the center shaft or diff input pinion (canít remember exactly which one now). All three Tetons I have had the same issue.
    The fix was to assemble the F/R plastic diff housings and run a drill bit down the input shaft entry. From memory it was a 6 or 6.5mm bit.
    Very easy to do and the driveline just will not work properly without doing it. I donít know if itís been fixed in more recent moldings.
    But that issue will lead to overheated motors etc definitely.
    I have a few links to lipos / motors etc that I liked too and will post later, just on phone now.
    Also you will eventually need metal driveshafts. Iíve had good luck with the hot racing and GPM. Probably prefer the GPM, cheaper and donít rely on a fine o-ring to retain the cover that holds the CV pin in.
    Jan 2019
    23
    Quote Originally Posted by boosta View Post
    Awesome! Thanks for the thorough response!
    I'm in no hurry so take your time.
    How did you find out the drive train was binding? I didn't know that was even a thing.
    I'd love to be able to keep running my stock motor for a while.
    I don't need a speed demon yet :-P
    389
    Yeah the stock motor goes quite well. A good upgrade is the 2S lipo as you were asking.
    This is the lipo Iím using. Nice little hardcase...
    https://*********.com/en_us/1600-2s-...___store=en_us
    I found the binding when doing a ground up rebuild. Itís always a good idea when rebuilding or maintaining to check for free movement at every stage completed, whether itís driveline, steering, suspension etc.
    I was checking after installing only the front and rear diffs to the chassis with the center shaft between them. Nothing I did would stop the binding, I checked every screw to make sure I wasnít overtightening etc. eventually I found the fault inside the diff cases.
    389
    Oh, I see the forum wonít allow a link to that site. Didnít realise that was off limits.
    Itís a ******* 1600mAh 2S hardcase. Hope thatís ok to say.
    389
    Ok. I see the forum has issues with that vendor. Iíll keep that in mind moving forward.
    Jan 2019
    23
    Was it actually keeping things from moving?
    Like locked up?
    389
    No, just causing friction. Iím just looking through the pics now trying to find them. Seems thereís a mix of pics and short vids so it might be best to edit them into a video to make it all concise. That will take a bit longer.
    In any case Iíll post the relevant pics so you can see ASAP...
    389
    Hi mate, I found a few pics but Iím sure thereís more there somewhere, just canít find them at the moment. Probably is some bulk phone download folder.
    This is where the problem lies. My memory is a bit vague as this was a while ago, but from memory it was in both the front and rear.
    There are two causes...
    The first is where the diff case comes in around the shank of the diff pinion, it binds and creates friction.
    The diameter of the diff pinion there is just over 6mm and the hole in the diff case is just under.
    The solution is to screw the case halves together to hold them firm...
    And drill out the hole to 6.5mm...
    Then deburr...
    The second part of the problem is due to incorrect spacing between the back flat of the diff pinion and the diff case. When power is applied the pinion is pushed backwards. Thereís nothing spacing it and stopping it being pushed back and rubbing on the case. The shim is indicating where the problem is...
    I used a washer as a shim to space the pinion from the shaft bearing (I canít remember what size the washer is sorry! But itís easy once youíre in there to work out what size you need.)
    Hope that helps!
    389
    To give the diffs some limited slip this is the best grease I was able to find from hpi...
    These are the GPM driveshafts...
    They need some shims to be spaced correctly...
    389
    Regarding the electronics, I donít want to fall foul of the forum policies regarding posting about companies that are in their bad books, so until I know more Iíll just post a couple of pics of the finished result.
    1/10 foamies...
    389
    I should have said earlier that if you can pull your motor pinion away from the spur and your whole drivetrain spins freely then you donít have a problem and no need to dig down into the diffs.
    My Tetons are a few years old and the diff pinion or cases may have been fixed in that time. Your mileage may vary.
    If yours does have a binding problem like mine did though, I hope that helps.
    Enjoy! Theyíre a super fun little car hey
