Havent had much time for this lately so im putting it on as a feeler. $350 shipped, make reasonable offers. No trades. Serious buyers only please.
Used but well maintained and adult owned. Works without any issues. It has some telemetry sensors installed and just needs a bluetooth adaptor and a TSM TQi remote use. Please see below list of what it comes with and what it does not come with. What you see is what you get.
Traxxas 4 pole VXL 3S esc/motor
Savox 0231 metal waterproof servo
Traxxas TSM receiver
Proline badlands mx28 tires (lot of tread left)
Traxxas 17mm wheel adaptors
Voltage tap installed (reads volts left in battery not BEC)
Motor temperature sensor installed
New in packaging 86T and 90T spur gears
Traxxas red aluminum castor blocks
Traxxas red aluminum front and rear carriers
Traxxas red steering and camber links
Red aluminum shock caps (traxxas brand?)
STRC hinge pins
RPM front (offset compensating) and rear arms
RPM front and rear shock towers
Traxxas monster jam extended body mounts
RPM ESC cage
Red ESC plate
Slash 4x4 steering bellcrank
Slash 4x4 HD drive shafts
Integy roll cage
Integy motor heat sink (had to cut it to make it fit)
Stock slash body that was cut for the larger tires (used)
Rear shocks are slightly bent and need to be replaced. The motor shaft also has a mark on it from a pinion that came loose. I tightened the pinion and the mark has not affected the functionality.
*** Does Not come with: a radio, battery, charger, bluetooth module, 17mm wheel wrench or anything else thats not mentioned.
