Results 1 to 23 of 23
    May 2019
    Michigan
    57
    Diff Problems PLZ HELP!!!!
    IVe replaced the diff once already striped again what do i do?
    Jan 2019
    184
    What power plant are you using? How is your slipper set? Try loosening or detuning it.
    May 2019
    Michigan
    57
    Vxl 3s I will try the slipper clutch loosening is there anything I can do to upgrade my transmission
    Apr 2019
    116
    Try the Hot Racing Super Duty Slipper system. If you're on loose dirt, bumpy, grass, etc., try tightening the slipper down all the way, then back it off a 1/4 turn or so. Keep checking things after a few laps. Tighten or loosen as needed for the vehicle to perform as needed.
    May 2019
    Michigan
    57
    Thanks for the help will try all things
    Oct 2016
    4,205
    Quote Originally Posted by Sharkbait View Post
    When you get serious and want to drop some money, look at the FLM super diff. If your problems arenít solved with clutch adjustments and driving habit modifications.
    May 2019
    Michigan
    57
    Ok so now I’m mad. I got the hot racing slipper and it does not work with the RPM gearbox because it rubs on the aluminum. So I just used the stock slipper clutch. I have not had a problem with the diff since but this is the third time stripping the idler gear. I don’t really know what to do and would really like some suggestions. Also should I do what this video says https://www.youtube.com/watch?v=TZOh...frags=pl%2Cwn? OF course then I would have to lose the RPM gearbox but id rather do that then strip gears all the time.
    N. Idaho... Da Sticks!
    7,570
    Sounds like you are just throwing parts at it...
    You need to figure out what is causing the problem, or get rid of the old transmission completely. There are five things that typically cause stripped gears in transmissions.
    1. Bad gears. Not common, but it happens. But, when this happens, it can cause other things to go wrong.
    2. Over powered. You are using a VXL, and even on 3S, shouldn't destroy the drive train.
    3. Slipper too tight. General place to start with the slipper is to tighten it up all of the way, then back off 1/4 turn.
    4. Bad bearing(s). When you do have a failure in your transmission, you should remove all of the bearings and check them to make sure they still roll smooth and true. If the race is mess up your bearing will wobble, causing the shaft riding in it to get out of position. From this your gear mesh changes and you are eating them.
    5. Bad bearing seat in the transmission case. When you take out your bearings for inspection you should take a hard look at the bearing seats, makes sure they are not damaged, make sure the bearing sits in them firmly and that there is no side-to-side movement of the bearing when properly seated.
    May 2019
    Michigan
    57
    Thanks i will do all these things then see what to do next
    Apr 2019
    116
    Sorry you're having issues. I would check that RPM gearbox. I have the hot racing slipper clutch in mine and there is plenty of clearance in between the gearbox and the slipper. I don't know why yours is rubbing? Also, take a look at Demon Rustler Upgrade 67 as far as how to assemble the sealed diff. I think it is a much better tutorial.
    May 2019
    Michigan
    57
    Thanks for the help everyone! I had a few bad bearings witch were probably from the sand dunes. I’m gonna try to make it to the LHS to pick up parts. Also my cousin has a Bandit that he’s selling to me for $85. Can’t Wait hope this solves my issues
    May 2019
    Michigan
    57
    Ok question I replaced all the bearings because they were all shot. Am I stripping gears because I have a diff locker?
    Oct 2016
    4,205
    Doubt it. Iíd guess loose gear mesh. Caused either by you or tranny case flex
    Jul 2019
    Boston
    137
    Quote Originally Posted by OtisWhitestone View Post
    The Demon Rustler vids are great, especially for the hot racing sealed diff. The only thing I’d add to his already great tutorial is to use something like associated green slime on all the o-rings. Pretty sure it’s just a green moly type. I just pulled this diff from my Rustler after running 20 or so batteries through it, 2s & 3s, and it didn’t seem to lose any of the 30k traxxas diff fluid I’d used.
    May 2019
    Michigan
    57
    Did it again now I’m stumped any help?
    Jul 2019
    Boston
    137
    Did it again now Iím stumped any help?
    Did what again?
    Sep 2012
    Hammonton Nj
    705
    Easy fix, buy FLM super diff and be happy forever
    ask rc DAD
    Jul 2019
    Boston
    137
    Itís true Role! Iíve used the diff with and without the H-Bar, with and without the shims on the output shafts, and it works flawlessly both ways.
    I also have a four year old driving it, with a 2250kV motor shoehorned in there. Being able to use those spider gears is a game changer!
    Jan 2019
    184
    Try going without the diff locker and see if that helps, because the super diff is 100 dollars. That is a lot of cheddar.
    May 2019
    Michigan
    57
    Yeah and I’m short on money too so I will try
    Jul 2019
    Boston
    137
    Yeah and Iím short on money too so I will try
    Good call. I had the diff locker and it was fun for driving on loose surfaces, but thatís about it. Itís not all that practical for an all around basher. It will definitely lead to broken parts elsewhere in the truck.
    If youíre on a budget, check out the hot racing sealed diff. It fits in the stock tranny, and uses all stock internal parts.
    If you go that route, check out the demon Rustler video on you tube. Itís about perfect, except he does not use green slime or any grease on the o-rings (you should definitely do this), and I canít remember if he used thread locker on the screws, but you want to do that too. Tighten carefully in a criss-cross pattern.
    Sep 2019
    SharkBait you might try a hit racing Diff. It is sealed. That is my next big upgrade for both of my two bandits.
    May 2019
    Michigan
    57
    Thanks all hopefully this will fix my problem. I will also install the RR idler gear
