    Jul 2019
    4
    E-Revo squeaks when driving
    Iíve had my E revo 2.0 for 1 month now and Now my e revo squeaks when driving. There has to be load for it to squeak. Whenever I brake it makes the squeaking noise and whenever Iím driving relatively slow it squeaks as well. Iíve cleaned the bearings on the wheels and put 1 drop of 3-1 oil on the bearings. The sound sounds like itís coming from the rear drivetrain. Anyone have any idea on what this could be?
    Jul 2018
    357
    Dry lube the arm pins in the bulk head. This is probably your culprit.
    Jul 2019
    4
    What kind of dry lube do you recommend?
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,681
    Have you ever heard an xmaxx? They "squeak" like no tomorrow. After my first run or two I noticed it. I joke with all my xmaxx friends how it sounds the same but is twice as fast!
    RC Qualifier Rcguy5's Avatar
    May 2016
    Phoenix, AZ
    267
    The squeak is the driveshaft in the rear, this bothered me on my summit for a while. I used to just WD40 the shaft but it only lasted one run until it was back.
    SLAM!
    "That Tree jumped right in front of me"
    Jul 2018
    357
    Quote Originally Posted by Dittydog View Post
    I use graphite, lhs should have it. Also local hardware stores will have it market as door lock lube. Cpl spray works as well. Could use wd40 but not ideal.
