    Aug 2015
    452
    Batteries in parallel
    I think the answer is yes but i'll throw this out there. If you have 2 50c batteries in parallel does that make the output 100c?
    20,522
    C-rating is a measure of a cell's continuous discharge rate.
    Whether cells are connected in series or parallel, the C-rating does not change.
    HOWEVER, since maximum current draw equals capacity times C-rating;
    AND you've effectively doubled the capacity;
    the maximum current draw will be doubled.
    Alt-248 on the number pad =
    13,459
    Parallel doubles the gas tank - mah.
    Aug 2015
    452
    Ok, thanks. So i guess the reason my drag car accelerates faster is there are more amps available at the batteries 50c rating.
