Results 1 to 13 of 13
    Jan 2015
    85
    What's The Largest Motor The Stock Mounts Can Support
    Hi Everyone,
    Playing around with speed runs, and noticing some very high motor temps due to aggressive gearing / with 4S lipo, on the existing Castle 2400KV / Mamba X combo.
    From your experience, what is the largest 1/8th motor, that I can install, without modifying the motor mount? Would ideally like something 6S capable, to better manage heat, even though I'm not likely to actually go 6s.
    Currently running MOD1 pinion and gearing (21T/38T). I fully understand that a larger motor, with reduced KV will drop the speed etc.
    Thoughts and suggestions appreciated.
    Thanks.
    Nov 2018
    Livermore, CA
    367
    Do yo have the HCG or LCG chassis?
    I know the LCG chassis can take a 2200kv motor for the UDR, but the pinion choice will be limited due to the wider can that restricts movement.
    64
    So can the HCG...take a 2200kv
    Sent from my iPad using Tapatalk Pro
    Jan 2015
    85
    Sorry, should have mentioned it's a LCG chassis. With that in mind, do you think my current MOD1 setup of 22/38 would still fit?
    Jun 2017
    Ohio
    1,343
    Are we talking length or diameter?
    Feb 2002
    9,401
    I have a 4269 in an lcg
    Jul 2019
    51
    I have a 4600kv hobbywing in my stock chassis 4x4 haven't taken her for a rip yet but I'm excited!
    Sent from my LG-US998 using Tapatalk
    Jan 2015
    85
    Diameter, while using the stock motor plate. I was thinking of picking up an Arrma BLX 2050KV motor only because its affordable.
    Jan 2015
    85
    Which motor is that? Did you modify the motor plate?
    Jul 2019
    51
    Not stock motor plate but the slightly upgraded aluminum one.
    Jun 2017
    Ohio
    1,343
    Quote Originally Posted by gusd2 View Post
    That fits for sure diameter wise.I have one.
    Not sure what your ESC setup is to accommodate the length. It's a 75mm long motor. I have an HCG chassis with my reciever box mounted up front and I currently have a 4275 in mine. You can make it fit for sure.
    RC Champion Dcuda69's Avatar
    Jan 2015
    WI
    2,976
    I have an LCG with a 4074 2150kv running 20/50 gears. Drops right in after moving the receiver box up front. Stock(Ultimate) motor plate with a King Headz mount.
    Slash 4x4 Ult 2150kv
    Rustler vxl
    Ford GT vxl
    Jan 2015
    85
    Thanks guys for the pictures and details. Really appreciate the support!
