Results 1 to 12 of 12
    Dec 2018
    40
    Proline badlands mx43
    Any thoughts on the proline badlands mx43 ? I hear they are heavier then the factory wheels and tires, is the weight difference enough to affect the servo?
    Nov 2015
    609
    Theyre great but are much heavier than stock and do reduce performance. I was happy with how my stock motor geared 22/46 with a Max 6 performed, but with the badlands, Ive felt the need to upgrade to a bigger motor and a Max 5.
    I run the 2085x servo, and that seems ok with the Badlands. I believe the spec is the same as the stock servo this one is just more reliable.
    The Badlands a great upgrade, but they’re expensive and I think theyre best suited for trucks with upgraded motors
    Dec 2018
    40
    Thanks for the advice Kpowell911
    Oct 2016
    4,193
    2085X is stronger and faster than stock. Iíve never used stock tires so comparing I canít do. Heavier tires with upgraded electronics seems to make the truck more driveable(sp)
    Apr 2007
    Long Island, NY
    361
    Quote Originally Posted by FLexus Lexus View Post
    I got lucky and picked up a set of 4 practically new Trenchers .43ís for $70 !!!!! These are heavy also but I have to say I am stoked over their on road and off road capabilities.
    I did up grade to the 2085x servo.... seems to preform well and with enough torque to push those tires around.
    I said go for it.
    Jul 2019
    ny
    9
    I just installed the savox and it throws the badlands around like nothing. The stock servo had the wheels moving all over the place in high speed sweeping turns.
    WEST PALM BEACH
    57
    which savor did you install ?
    Jul 2019
    ny
    9
    2290sg. I also run it with a bec at 7v and it is lightning fast.
    Apr 2007
    Long Island, NY
    361
    Quote Originally Posted by ctony View Post
    Which BEC do you run it with. I’m running it straight out of the receiver box. Seems ok!
    Dec 2017
    Van. Island British Columbia
    834
    Quote Originally Posted by REVO-KN-EVIL View Post
    If you tend to run in wet areas or seasons this is one of your best options. Some people seem to run those without a bec with no issues and others have issues.
    http://www.castlecreations.com/en/ac...or-010-0153-00
    Jul 2019
    ny
    9
    Castle waterproof like mentioned above. Only need to connect to one of the battery connections. Just pull the wires out of the connection and solder them on then push them back in.
    Oct 2016
    4,193
    Which BEC do you run it with. Iím running it straight out of the receiver box. Seems ok!
    I have that servo. Very nice piece. I run the CC 2.0 WP. Itís recommended you connect all the receiver power plugs. So I did. Donít want to lose any capacity.
