Page 3 of 3 FirstFirst 123
Results 81 to 93 of 93
  1. #81
    Dec 2014
    Adirondacks
    1,489
    Quote Originally Posted by Bob2.0 View Post
    I'm going to convert my Revo back to nitro. The final straw was that cerakote increased the cost of there smallest ceramic coating from $15 to $30 and shipping costs and extra $20...
    Yup. Its roughly 5 times cheaper to run.
    Here is my Gasoline revo
    $30 coating + extra $20 = $50. Wouldn't it make sense to run gasoline at $3.00 a gallon vs. nitro fuel at $40-$50 a gal?
    Why convert back to Nitro?
  2. #82
    Aug 2019
    108
    Theoretically, but I'm not positive the ceramic coating will even work. I have already blown an ez start, ez start motor, ez start battery, a pull start, and engine back plate because it takes a lot more turning over to start and the high compression doesn't help either. The reason it takes so long to start is the carb is too big so it takes a lot to get the fuel flowing even with priming and the choke. Also with the carb that's too big it doesn't like sudden large throttle changes. So over the quarter gallon of gasoline it has had through it I have payed way more in replacement parts than I would have payed just for a gallon of nitro.
    Finally I have dreamed of this rc car sense 1st grade. I now have one and it sits around not being used because I don't have the time to finish the trial and error process to try and make it run well. I finally got to go bash RC cars with my uncle a week ago and I forgot how much I missed it. I probably hadn't bashed an RC car in 3 months when I finally did it last week. It basically comes down to I would rather pay $50 per gallon and use my car than watch it sit and never get used.
    I should have more time this summer so I may revisit the conversion then. I really want to run gasoline but I just don't currently have the time.
  3. #83
    Dec 2014
    Adirondacks
    1,489
    That's the best answer! It's not about proving right or wrong, but to have fun. And to be able to enjoy that time with family and friends makes it that much more special.
  4. #84
    Aug 2019
    108
    I got some pics of the porting. I tried to reflect all my porting with the port jobs that RB mods does and with everything else I have read on porting these engines. I know its not near perfect but I noticed a large jump in power all round but primarily in the top end.
  5. #85
    Aug 2019
    108
    Crankshaft- I tried to keep the CG of the crankshaft as close to the same as possible so it isn't too off balance. I also bored out the hole a bit that travels from the carb to the crankshaft. Finally with my Dremel I delayed the closing of the intake by a degree or two to increase top end in sacrifice of some bottom end power.
  6. #86
    Aug 2019
    108
    Sleeve- just basic fang mods
  7. #87
    Aug 2019
    108
    Other parts- top is the carb I crammed on my revo. bottom is a stock cylinder head vs my modified cylinder head.
  8. #88
    Jan 2014
    47
    Bob, you mentioned reading about porting a 3.3. Can you give some references? Just wondering if it would help a nitro only motor.
    Thanks ahead.
  9. #89
    Jan 2014
    47
  10. #90
    13,969
    Link doesn't work. But if it is a link to porting a nitro engine then you can do it. Practice on an old sleeve so you can work the bugs out of your hands and abilities. I've done a very mild port to my old 3.3 and it seemed to work - but that engine had a piston from one engine, sleeve from another and was repinched.
  11. #91
    Jan 2020
    Long Island
    40
    Hey guys anyone have have pics on a simple port and polish on the 3.3?
  12. #92
    Nov 2018
    Brasil
    3
    I will try this mod.
  13. #93
    Aug 2019
    108
    You can see pics above of basically all the porting I did.
    I absolutely loved my engine right after I ported it. It had TONS of power both in the top and bottom end. I was honestly struggling to keep the two front wheels of my Revo on the ground (it was a short chassis which made it worse) It also became a breeze to tune and held it's tune very well. Sadly while messing with running gasoline in the engine, I way over heated the engine quite a few times and it lost the majority of it's compression. So as of now it won't hold a tune for more than half a tank, the idle is finicky and inconsistent, it runs a lot hotter, and it runs like crap when cold. Granted once warmed up it has the same top end power as a newer stock 3.3 engine.
    I'm just waiting to find a brand new engine that someone was parting out or if I can't find one soon I will just trade the engine in for a new one.
