Results 1 to 12 of 12
Thread: please help me!
    Aug 2019
    please help me!
    Hey guys, I took my erbe out of town with me and left my charger at home since my buddy brought his. He has a radient ascert 80w charger. I have 2 almost new (ran for not even two packs) 2s 5000mah 25C lipos. They have no problem on my charger but we cannot get his to charge them. It just keeps saying "balance port cell low vol". Of course I have it set for 2s at 2.0 amps with balance port plugged in.
    Need help I brought this thing 10 hours away and can't play with it!
    Thanks
    Jul 2019
    Greeley, CO
    546
    Did you test them out on his charger before deciding to leave your charger at home?
    Are they Traxxas Batteries?
    Is there a LHS nearby?
    Jun 2017
    Ohio
    1,354
    Only way to know is to check the individual cells of the battery. If any of them are below 3.0v most chargers won't charge them. You can try putting the charger on NiMh and charging them at 1 or 2 amps for like 2 minutes to try and get the cell voltage up over 3.0v. I wouldn't do anything until you verify what the individual cell voltage are on the pack.
    Dec 2003
    Dekalb, IL
    2,655
    Do you have the packs with the ID connectors? If so, I'm guessing you have the adapters to be able to charge them on a non-traxxas charger. You mentioned balance plugs, so wasn't sure if you had old traxxas packs that used balance plugs or if you were using adapters.
    Expert rigging at it's best!
    Jul 2019
    Greeley, CO
    546
    I think the OP is a one and done poster...they haven't responded since posting...
    Aug 2019
    spambot post
    Jul 2019
    Greeley, CO
    546
    Quote Originally Posted by Isuzuhn View Post
    spambot post
    Okay?
    So the translation reads:
    translated spambot post
    Still doesn't make much sense.
    Not quite sure what to make of this whole thread! ...MODS?
    Dec 2003
    Dekalb, IL
    2,655
    Spammerfic.
    Jul 2019
    Greeley, CO
    546
    Spammerfic.
    I don't get it though...why go through the setup then post nonsense...where's their payoff? To what end?
    Wasting everyone's time and goodwill...
    13,734
    Quote Originally Posted by USMC1984 View Post
    It gives the impression that a newcomer is genuine which will initially get past members and moderators. Then they post a reply which triggers previous viewers to look again and read the post and hopefully click the link. Spammers do show up here but not to the degree they used to. If you suspect one hit the triangle with the exclamation point below their name to report the post.
    Jul 2019
    Greeley, CO
    546
    This particular one didn't make much sense though. How many people are going to read Vietnamese or even want to buy an Isuzu from Vietnam? Let alone they posted it in Vietnamese and even translated was still quite cryptic. Geesh, at least tell us we can make 40k a month with their secret system or that we have inheritance from a deceased uncle in Nigeria.
    20,535
    Itís a machine following its programmed algorithm. It doesnít care.
    Alt-248 on the number pad = į
