    Aug 2019
    3
    my full-mod UDR build
    Hello everyone. I recenly found this forum and I am glad to be part of the community.Greetings to all. Long story short ,what started as a wife's present for my birthday quickly tranformed into my next long term project. Here are some photos of my UDR which i am currenly modding/upgrading. At the moment this is what i have upgraded
    Vidavon aluminum rear axle housing
    Vidavon metal planetary gear housing
    Vidavon Aluminum trailing arms
    New enron Steel 6mm upper tie rods with metal end caps
    New enron alloy rear axle hubs
    GRC wheel hex hub brake discs&calipers (front and rear)
    Hot racing travel limit straps
    Rpm cnc alloy motor cooling Bracket/mount
    Rpm sway bar kit (front&rear)
    New enron alloy C hubs
    Vidavon alloy lower Arms
    Vidavon alloy upper A-arms
    Vidavon alloy front bulkhead & differential housing
    Vidavon alloy central transmission housing
    Rpm aluminum shocks with piggybag (all 8)
    Rpm steel front linkage
    Rpm aluminum steering assembly
    Rpm alloy shock absorber mounts
    Stainless steel skid plates
    probably forgot something but oh well ...
    https://www.flickr.com/photos/183325...posted-public/
    I have not yet touched the electronics since the car is pretty fast on 6s. But i am planning on a modification to the plastic chassis where i will enlarge the battery compartment to fit 2- 4s batteries after i upgrade the motor and ESC and servo.
    I am now designing a steel roll cage. I will post photos of that too as soon as i have something decent to show lol!
    Apr 2003
    Smithfeild , NC
    149
    looks great !!!!
    Xmaxx , XO - 1 , Slayer Pro , UDR , E-Revo
    Oct 2014
    Vegas
    243
    wow, first time seeing those RPM shocks.
    Do you have a part number for those?
    Aug 2019
    3
    I dont remember the part number but they are available in alliexpress. They have harder springs and if your car is not heavy you better use the OEM springs. Mine weighs 8.1 kilos batteries included and they are still too stiff even without any pre load. After i finish the steel roll cage i think they will work fine. They are good for jumping though!
    Aug 2019
    3
    https://www.instagram.com/p/Bz2sscWFN7y/
    https://www.instagram.com/p/B0A1uAWFQzB/
    Two clips I made this summer while the car was complete stock. Lots has changed since then...
