    May 2018
    28
    Pinion gear stuck on the motor shaft?
    The motor runs fine, The pinion moved back towards the motor, so about half of the spur doesnt touch the pinion.
    I noticed this when you would give full throttle from a standstill the rig would shake before take-off.
    I have taken the motor out of the truck, and the grub screw came out fine. The pinion was no longer aligned were the flat part of the shaft and the grub screw would connect.
    I have sprayed wd-40 on it a couple times, and can't get the gear to budge.
    If I put the exposed part of the motor shaft into a vise, and put a long screw were the grub screw goes I can get it to "spin" but only for a little bit at a time before the vise loses its grip on the shaft.
    Any tips on how to get this this off and hopefully reset?
    Eastern Shore, Maryland
    4,174
    You need a Tarot Metal RC Gear Puller. You can get it on Amazon for 19 bucks.
    May 2018
    28
    will that fit with a stock xmaxx pinion?
    I don't see different sizes?
    4,174
    It looks like it. I have a several different sized ones that I've had for years, so I'm in good shape. I don't have this particular one, but if it doesn't fit I'd send it back.
    May 2018
    28
    Thanks I appreciate it
    Sep 2018
    43
    This seems to happen to me everytime I change mine. I lock tight(blue) it and hand tighten it down real tight then when I change I struggle to get it off the motor shaft.
    I normally have to loosen the motor free and pull it out some. Then I hit the pinon so it moves closer to the motor. Then grab it with pliers and pull. Sometimes I have to repeat and try again lol.
    I should prolly just invest in the puller tool...haha
    Good luck!
    Sent from my SM-G965U using Tapatalk
    Oct 2015
    960
    Good find. I thought I was a genius when I bought something similar from Home Depot for my gears.
    4,174
    Quote Originally Posted by Nitro Blowin View Post
    If you guys are having trouble getting your pinion gear off due to Lock-Tight, and not because its jammed, all you have to do is heat up your pinion gear with a heat gun. Once heated up your gear will pull right off without any issues. You can also do this for set screws too. Keep and use your gear pullers on gears that are dry-jammed or pressure fitted.
