Results 1 to 21 of 21
Thread: ESC coolers
    Dec 2017
    Van. Island British Columbia
    835
    ESC coolers
    Looking for different ideas to cooling the esc as an add-on to the stock on the vxl 6s marine, any pic's or mods would be greatly appreciated.
    Thanks in advance.
    Sep 2015
    Chesapeake, Va.
    142
    Quote Originally Posted by Rain Dawg View Post
    Thanks in advance.
    Wait for RegularGuy to respond. He has had pics on this site somewhere of cooling for the ESC.
    Dec 2017
    835
    Thank you, I'm really considering putting in a VXL 8S and the 1200kv from the Xmaxx and run it on 6s and monitor temps just to see how it performs.
    Eastern Shore, Maryland
    4,045
    Don't do that. Those components are for land based RC vehicles, you'll burn them up using them on marine based RC vehicles.
    4,045
    You asked for it America, and now it's back by popular demand.
    I'll post these, and you can ask whatever questions you have. Here's the tools and stock you need.
    3
    4
    5
    Fabrication
    6
    7
    8
    Soldering
    9
    10
    4,045
    Soldering Continued
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    4,045
    Soldering Continued
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    4,045
    Walla! You now have a water cooled heat sink.
    31
    32
    Having this, along with a water cooled Castle CC Cap pack, and shortening my wires (total length between ESC and batter) to less than 5 inches reduced my temps from the high 180's to the very low 120's. Also, I got 8 good years out of my stock ESC.
    Here's a picture of how to make a mount for a CC Cap Pack. It fits over the receiver box.
    33
    Here's what the complete setup looks like.
    34
    35
    I put numbers by the pictures for easy reference just incase there happens to be any questions that come up. Good luck.
    P.S. This is for you, Rain Dawg...USMC and JOB. You should have three words now.
    Dec 2017
    835
    Awesome job and thanks, very much appreciated. I have the brass from another project except the brass tubing for the caps, so I scooped a couple of empty .45 ACP casings out of the reload bin and cut them down and they are going to work perfectly.
    My casing holder for cutting with the dremel.
    4,045
    I think the water tube size I used was 3/16 and the square tube was 7/32. The brass going around the caps has to fit snug for it to pull the heat away from the ESC caps properly. If sloppy it won't work. If to small it won't fit. What I did was I took my ESC down to the (LHS) and went though their different tubes until I found a brass tube with the snuggest fit. Then I took my brass tube to an electronics store and got caps that fit my brass tube.
    P.S. stopped #5
    Dec 2017
    835
    Quote Originally Posted by ReglarGuy View Post
    P.S. stopped #5
    I will definitely do what you suggest the next time I run into town, I was trying to utilize what I had on hand. Being out in the country and a 40 min. drive each way with fuel prices the way they are this at least gives me an idea what to pick up on my next venture.
    Dec 2017
    835
    So here's my version of the esc cap cooler, I added a 3rd tube because there was room. It doesn't look as clean as ReglarGuy's but it does function and hopefully it will work. The .45 ACP casings I cut to use actually fit really snug.
    4,045
    You did a really nice job. Hopefully, it will work for you. If not, just make your heatsink a bit longer. You want as much metal as you can (that will fit in your boat). The metal is what pulls the heat from your ESC, and the water is what cools your metal so that it can keep pulling the heat. Also, Toluene works really good for cleaning off the flux from your finished work.
    P.S. by #6
    Dec 2017
    835
    (Toluene) I had to google that word lol I'll look into some of this tomorrow and thanks.
    https://www.youtube.com/watch?v=FQVX...ature=youtu.be
    4,045
    If you close your eyes it sounds like a little kid taking a leak. (lol)
    Dec 2017
    835
    Haha it brought back memories when I heard it of my mother having that little boy garden statue that did that.
    4,045
    Ya, my mom had one of those too. (lol)
    P.S. order #9
    Dec 2017
    835
    When you used the larger diameter water tubing (3/16) did you have to widen the holes in the hull or did it fit ok without having to do that and when I add the second water line should I do it the same size as the Traxxas one or the new 3/16 line.
    4,045
    I used the Traxxas stock water tubing. I like it better, because it's the most pliable. It also doesn't kink. Because, I use the factory tubing, I cut my second hole the same size as the factory hole.
    Dec 2017
    835
    Excellent thank you, that's what I was hoping to hear.
    Dec 2017
    835
    I just ordered my dual intake rudder from OSE which should be a huge benifit along with the esc cooler to lowering temps.
