    Aug 2019
    Dual to single Servo Help - TRA2255
    I have a new E-Revo VXL Brushless RC. I blew out a servo within 4 days. I decided to change it to a single 2255 Heavy Duty servo, single servo setup. I purchased the following components based on the Traxxas webpage.
    1. Traxxas 5344X HD servo saver
    3. Traxxas 2255 servo - high torque - your page said the BEC was needed, listed below.
    4. Traxxas 2262 High Output Battery Eliminator Circuit - BEC. Is this needed, the parts don't seem to fit the Revo? If a BEC is needed on the Revo with this servo. Install directions are for a much different car.
    5. Traxxas 8247 Metal Servo Horn
    Does this list look correct? Is the BEC needed, is this the correct one? Has anyone else set their car up like this?
    Any help would be appreciated. Thanks. Scott
    Feb 2017
    UK
    547
    Servo saver is fine.
    Servo Horn will fit the servo, but isn't really needed IMO - stock horn would work fine.
    BEC is more for the TRX-4. You shouldn't need a BEC with this servo when installing into the e-revo 2.0 (at least that's what Traxxas has told me in the past)
    https://www.youtube.com/iftibashir
    Aug 2019
    This is good to know. I did see the BEC component was directed towards the TRX-4. Thanks. I'm going to give it a shot!
    Appreciate the speedy reply.
