All-
I've done some Googling and reading up and still have some questions.
First, can anyone share a document with the definitive answer to how much toe the 2WD Slash has in the rear?
Secondly, what is your favorite means of add/removing toe from you 2WD Slash?
Thanks in advance all!![]()
I'm not sure the exact toe degree but 2 degrees pops up in my head. The only option to adjust toe that I know of is the proline hd transmission, it comes with three different options, 0, 1.5 and 2 degrees.
RPM makes a trans case with the two a arm mount separate from the trans to adjust the toe at 0 and 3°. I believe it can be - or + 3° by switching from side to side. There are also bearing carriers that can be swapped from side to side to lessen the negative toe. I don't have brands or part numbers but i know they are out there.
Sent from my VS996 using Tapatalk
Thanks Gents!
What kind of racing are you thinking of doing?
Carpet oval
An Iroc body would probably look sick racing oval.
Deltaplastik makes a killer one, FYI.....
Custom works adjustable rear arms if legal .
New product! Allows up to 6° of toe forwards or back.
https://www.redrc.net/2019/09/pember...s/#more-173955
Yeah. They’re a bit much. My Slashes are pretty much all RPM.
Want those arms for my drag project..
Ya can't polish fertilizer...
