    RC Qualifier USMC1984's Avatar
    Jul 2019
    Greeley, CO
    496
    4-Tec aftermarket wheels?
    I'm looking at buying the Ford GT and was hoping to find out whatever info may be needed to know the specs on wheels so I may order aftermarket wheels for it.
    Do most road cars have the same wheel setup or are they very different?
    I'm particularly interested to know if the Kyosho Fazer Mk wheels will fit.
    Thanks for any info guys!
    EDIT: So, I guess what I'd need to know is the hex size and offset of the 4-Tec/
    Nov 2018
    Spokane, WA
    345
    12mm hex I had one and sold it I know you can put contact racing foams on and they fit 26mm front and 30mm or 45mm rear
    26 and 30 from contact and 45mm from Johns bsr Racing
    Jul 2019
    Greeley, CO
    496
    Quote Originally Posted by Overpowerxmaxx View Post
    Ah, thank you! Do I have to worry about offset or does that only matter with the stock body? I plan on putting a different body on it.
    Nov 2018
    Spokane, WA
    345
    I would say you have to try different ones and figure out which ones work the 45mm ones need wider hex hub
    ex stock hub is 6.9mm thick and you need 10mm thick one to clear the axle carriers
    the smaller width tires 26 & 30mm will fit with the stock hub
    Jul 2019
    Greeley, CO
    496
    Thanks for all your help!
    I decided to pick up the brushed chassis only at my LHS, so now I can Mic everything I need to before ordering any wheels.
    I probably should have just done that from the start.
    FWIW, I chose the brushed over the VXL because this is going to be a scale toy more than a runner. I figured when I do run the brushed has way less temptation to get on it and bang stuff up.
