Results 1 to 10 of 10
    Aug 2019
    6
    Question Limit range of the servo
    Iíve got a new 25k Hexfly servo and installed it into my Stampdede 4x4.
    It works great, but it rotates couple degrees more than needed when I apply maximum steering. It causes unnecessary strain to other parts, horn touches the base and the driveshaft.
    How can I limit the range of the servo?
    Dec 2003
    Dekalb, IL
    2,340
    Are you using the stock servo arm or did it come with one you can drill a hole in closer to the servo output shaft? If it came with one, you can limit it that way somewhat.
    Depending on the radio you have, you may be able to adjust the end points as well. If it's a TQi, depending on the version, you can adjust that stuff. Info is in the manual.
    https://traxxas.com/sites/default/fi...24GHz-INST.pdf
    Expert rigging at it's best!
    Aug 2019
    6
    Even stock arm touches the driveshaft, so drilling a new hole won’t help : (
    I have stock radio wit a single center adjustment knob.
    I haven’t found any info in the original manual.
    Are there any other ideas?
    Dec 2003
    Dekalb, IL
    2,340
    If it's the old AM one:
    https://traxxas.com/products/parts/l...arts/2227tq4ch
    Or this one:
    https://traxxas.com/products/parts/6516
    I don't think you can adjust it at the radio and can only adjust it mechanically. Short of that, you have to get a transmitter/receiver that has the adjustments built into them.
    Aug 2019
    6
    6516 is the transmitter I have.
    I suspected that getting a new transmitter is the only option, but was hoping someone can suggest another option.
    Is there any option to mechanically adjust the servo? Some magic adjustment knob inside the servo body?
    Jan 2019
    184
    This is what he said.
    Jul 2013
    Northern Norway
    867
    Quote Originally Posted by dima81 View Post
    From the top of my head, I can think of three options to limit the servo throw electronically without changing the Tx:
    https://www.freewebstore.org/heyok-p..._18344974.aspx
    https://modelradioworkshop.co.uk/sho...oint-adjuster/
    (I use three of these in my TRX-4)
    http://www.simprop.de/Seiten/Modellb...ateReverse.htm
    These devices are not waterproof, but will fit into the receiver box.
    Aug 2019
    6
    Thank you very much, @Viking
    Dec 2003
    Dekalb, IL
    2,340
    Quote Originally Posted by Viking View Post
    Man, I completely forgot about those things!
    Jul 2013
    Northern Norway
    867
    You're welcome, dima81.
    That's why us old-schooler's get increasingly flat foreheads with age...
