    Aug 2019
    UK
    Exclamation Help please: Summit getting no power onto the ground?
    My Summit is whining badly with the motor running OK - the pinion and spur gears are engaged and turning fine - I have tried everything with the Slipper nut (looser / tighter) but still it can't get the power being generated into the wheels and move away properly..... if it does it sounds very laboured and is very slow.... sometimes it just stands still and won't move hardly at all.
    What can the experts suggest please? the problem seems to be between the Spur gear and the driveshafts which all seem fine also..... if you manually turn the wheels while holding the vehicle it does turn the gears and the motor ......
    Thanks
    Nov 2018
    Spokane, WA
    316
    Check your front and rear diffs for stripped gears
    Aug 2019
    UK
    Quote Originally Posted by Overpowerxmaxx View Post
    Thanks I'm gonna tear all that apart next!
