Results 1 to 10 of 10
    Feb 2019
    Montana
    25
    Traxx Too Tall For Snowplow?
    Fall is fast approaching and there will be snow on the ground before we know it so I'm looking into getting the RC4WD V-Plow for my defender with Traxx. I'm wondering if the Traxx make the truck too tall for snowplows? Or do most of the plows on the market go low enough to compensate for that? It wouldn't be the end of the world if I had to use tires to plow snow. I just want it to be pretty effortless with plowing.
    I think I read somewhere that Traxxas may be developing a snowplow of their own... Any truth to that?
    Also any advice with setting up the servos with the channels would be much appreciated. I haven't really worked out how that would work yet.
    Thanks!
    TRX-4 Land Rover
    X-Maxx 8S
    LaTrax Alias
    Mar 2004
    N. Idaho... Da Sticks!
    7,576
    I don't think they will. You might have to do a little modification to get the whole mess right, but it shouldn't be that big of a deal.
    Haven't heard of Traxxas coming out with a snow plow, but given Traxxas' recent release history, nothing would surprise me.
    Here is the plow from RC4WD, the last to pictures are the plow mounted on a TRX4...
    https://store.rc4wd.com/RC4WD-Super-...ed_p_5819.html
    5,642
    I've heard rumors of a plow from Traxxas from a few different people, so who knows. I've seen a TRX-4 with an RC4WD plow so I know it's possible.
    Feb 2019
    Montana
    25
    Any idea how to use a servo/channel for turning the plow?
    TRX-4 Land Rover
    X-Maxx 8S
    LaTrax Alias
    Mar 2004
    7,576
    Quote Originally Posted by justinj360 View Post
    It depends on if you are planning on using an aftermarket radio, or the stock TQi.
    You'll need two channels, one for raising and lowering, and the other for turning the plow. The whole mess would be fairly easy using one of my Spektrum DX5 radios, would just need two free channels. If the TQi was my only option I would ditch the locking diffs and 2-speed transmission, you'll want low-speed and locked diffs when you are plowing, so neither would be a loss. I would use transmission select for the raise/lower function, and the diff-lock control for the direction (left/middle/right). Another option would be to get a cheap TX (like a Flysky), and use that just for running the plow.
    Feb 2019
    Montana
    25
    Quote Originally Posted by Greatscott View Post
    I'll be using the stock TQi. I'd actually be using a winch to control the up and down movement so I'd just need a channel for turning it side to side. I'm using the RC4WD super duty plow btw. So do the diffs stay locked if you unplug them then?
    TRX-4 Land Rover
    X-Maxx 8S
    LaTrax Alias
    Mar 2004
    7,576
    I think they will stay locked, but I am not 100% for sure. Both of my TRX4s no longer have selectable diffs, one has spools and the other runs open. Recommend unplugging the servos and make sure they do stay locked. If nothing else, you could always use zip-ties to lock the servo horns in place.
    Feb 2019
    Montana
    25
    So I’ve got my plow set up except for the side to side movement. I’ve unplugged channels 4 and 5 for the locking diffs. I locked them then unplugged them so they’ll stay locked for plowing. I have the servo for the plow plugged into one of those channels.
    So when the lever is in the left position the plow is turned as far left as it can pivot (the servo wants to go more and gets hot if I leave it like that though). When the lever is in the center position the plow is centered too. Right does nothing at this time. How can I make it pivot right as well? What can I do about the servo not wanting to stop?
    Also it appears the Traxx do make it slightly too tall for the plow so I’ll probably just switch to tires.
    TRX-4 Land Rover
    X-Maxx 8S
    LaTrax Alias
    Feb 2019
    Montana
    25
    Would there be a way to connect the servo to channel 4 and 5 at the same time? That's the only thing I can think of that would work for this.
    TRX-4 Land Rover
    X-Maxx 8S
    LaTrax Alias
    Feb 2019
    Montana
    25
    I’m at a loss here. I have no idea how to make it turn right too.
    TRX-4 Land Rover
    X-Maxx 8S
    LaTrax Alias
