Results 1 to 28 of 28
    Dec 2018
    34
    Slash 4x4 platinum edition parts question
    Hi:
    I have two questions about Slash 4x4 platinum edition parts I hope you can help me.
    1. From this top view picture, you can see that my two rear wheels have a angles. Is this normal?
    2. My car hit the wall at high speed and broke the from part where I host the front bumper. Please see the picture here What is this part called? Can I replace it?
    Thanks,
    Feb 2002
    9,352
    the broken part is the bulkhead, yes you can replace it
    yes, the rear has quite a bit of toe-in. if you run aluminum rear blocks, and put them on the opposite side, you can get rid of most of that excessive toe-in
    Jan 2019
    SF Bay Area
    671
    The plastic rear carries have 2.5° of toe-in, and swapping sides doesn't change anything. The aluminum carriers have 4° of toe-in when installed properly (left on left, right on right). If you swap them (left on right, right on left), then you end up with 1.5° of toe-in. If you've running more "straight" than "turns", leave them as they are (4°)...if you've running more "turns" than "straight", swap them.
    Alternately, you could replace the Traxxas carriers with STRC carriers, of which they offer 0° & 0.5°. If I understand correctly, the 0° will produce the same results as the Traxxas carriers, whole the 0.5° carriers will produce 4.5° (normal) & 2° (swapped). For my Rustler 4x4 (same parts in this area as the Slash & Stampede 4x4s), I purchased the 0.5°, and swapped them. Results on the track are quite nice.
    Jun 2014
    Southern California
    7,529
    Quote Originally Posted by Panther6834 View Post
    Correction: Swapping sides of the Traxxas aluminum rear carriers gives you 1° toe-in.
    Jan 2019
    SF Bay Area
    671
    Interesting, as elsewhere in this forum, there's indications of 1.5°.
    Feb 2002
    9,352
    I would trust Squeegie before I trust some rando poster...
    Jun 2014
    Southern California
    7,529
    The Slash 4x4 rear has a built-in 2.5˚of toe-in. The aluminum rear carriers have 1.5˚ of toe.
    Installing as labeled: 2.5 + 1.5 = 4˚ of toe-in
    Installing reversed: 2.5 - 1.5 = 1˚ of toe-in
    See pages 23 & 24 of the Slash 4x4 Ultimate Owner's Manual:
    https://traxxas.com/sites/default/fi...-OM-EN-R04.pdf
    Jan 2019
    SF Bay Area
    671
    Coming from you, Squeegie, I trust it's accurate. I was only mentioning what others had posted (regarding 1.5°)...a trying to claim it was accurate.
    Jun 2014
    Southern California
    7,529
    Just wanted to make sure you got the information from the source (owner's manual) and not just spread hearsay.
    If you want more adjustability, you can get the Tekno M6 rear driveshafts with rear carrier.
    With Tekno's rear carriers (the kit includes 2 sets), you can set it for 1˚, 2˚, 3˚, and 4˚.
    You can also adjust the roll center of your rig:
    From Tekno's manual:
    https://wwwcdn.teknorc.com/wp-conten...ctions_new.pdf
    Their front driveshaft and carrier kit also allows for adjustment of bump steer:
    https://wwwcdn.teknorc.com/wp-conten...ctions-new.pdf
    Have a great weekend!
    Dec 2016
    Burleson, Texas
    234
    OK, since everyone else is busy actually helping I'll ask.
    What all is on that machine! I see several USB, processor, buttons and a bunch of other things. Is is autonomous?
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    Jun 2014
    Southern California
    7,529
    Quote Originally Posted by Scott91370 View Post
    Yes.
    Read this thread:
    https://forums.traxxas.com/showthrea...Lower-car-body
    Indianapolis
    14,173
    Forgive me if I'm mistaken. That looks like a broken front differential housing to me than a bulkhead. Maybe even an a arm that could use replacement.
    Dec 2016
    Burleson, Texas
    234
    Yes.
    Thanks! :-)
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    53
    I agree, to me it looks like a diff housing also
    Sent from my iPad using Tapatalk Pro
    Feb 2018
    555
    I can’t tell if anything else is broken due to the dark picture. But I agree the housing (pn6881) looks destroyed
    Dec 2018
    34
    Thanks everyone for your help.
    1. For the rear angle, It was probably because I inserted a tube inside the shocks following the instruction here https://www.youtube.com/watch?time_c...&v=uytvBXu4xKE The goal is to make the car lower. I do not mind having the angle, but just want to make sure the angle will not make the car slower or damage the car.
    2. For the broken part, I have a clear http://artlystyles.com/tmp/Capture.JPG here. The damaged part was pointed by the red arrow. What's its name and how to replace it?
    Thanks,
    Jan 2019
    SF Bay Area
    671
    I believe that would be the differential housing.
    Sent from my SM-N975U using Tapatalk
    Jun 2014
    Southern California
    7,529
    As others have said, front diff housing (p/n 6881):
    https://traxxas.com/products/parts/6881
    Feb 2002
    9,352
    ah, ok. initial picture was goofy looking
    it is the diff housing in the front bulkhead (which may also need replacing if it is messed up, can't tell, depends on the arm)
    the whole front of the truck needs to come off. how come you don't have a bumper on it?
    Dec 2018
    34
    Thanks.
    Looks like a lot of work to replace it. Any youtube video about how to change it?
    Feb 2018
    555
    Quote Originally Posted by gecong View Post
    Thanks.
    I think you should be able to just pull it off. Keep your a arms off the way they are and pull on it. I can’t really tell if it actually needs replacing though. Maybe I just don’t see it but it doesn’t really look broken
    Edit: keep bumper off. And unscrew the two screws to the direct right and left of the diff housing
    Dec 2018
    34
    Here is a picture about the broken part. http://www.artlystyles.com/tmp/IMG_8940.JPG. http://www.artlystyles.com/tmp/IMG_8941.JPG and http://www.artlystyles.com/tmp/IMG_8942.JPG The holes were used to host my front bumper from the top
    I also find some damage on the bottom of the car http://www.artlystyles.com/tmp/IMG_8943.JPG. The holes were used to hold my front bumper from the bottom.
    How can I replace them?
    Feb 2018
    555
    I don’t think you need to replace the bottom holes. But you would have to buy a new bulkhead.
    Dec 2018
    34
    Quote Originally Posted by ati View Post
    You meant replacing the differential housing, correct?
    Jan 2019
    SF Bay Area
    671
    Bullhead looks good...a little 'messed up', but certainly still usable. The differential housing, on the other hand, NEEDS to be replaced. I would also suggest/recommend replacing the plastic bullhead tiebar, if the current one is plastic.
    Dec 2018
    34
    Which one is the tiebar?
    Jun 2014
    Southern California
    7,529
    It is the black plastic part that sits sideways/vertically on the front of your bulkhead.
    It is available is anodized aluminum:
    Blue:
    https://traxxas.com/products/parts/6823
    Green:
    https://traxxas.com/products/parts/6823G
    Red:
    https://traxxas.com/products/parts/6823R
    Jan 2019
    SF Bay Area
    671
    While you're at it, order two, and replace the rear one as well.
