    Jul 2019
    What should I upgrade on my 2WD Slash?
    So I was just given a Slash 2WD and I believe it is an older one based on the remote (seems like a 2.5 T-Max type remote) and I am wondering what type of upgrades should I get for it?
    Jun 2017
    361
    Because it is older model, first thing I would check are bearings.
    List of available upgrades is huge but imho first thing I would suggest is upgrade your caster blocks to aluminum and if you like big jumps get some aluminum shock caps.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,082
    2.4 ghz radio system a newer stock setup or FlySky unless you can afford better. As alexsasax said bearing would be high on my list also but I would go straight for Stainless Steel. Because I like alittle water but hate complete teardowns after. Metal caster blocks is a must unless you are a perfect driver that never hits anything :P. If you are going for big air from jumps do your best to land well if you have the stock plastic shocks since they bend somewhat easy. A new shock rebuild kit will include the newer hardened shafts if you have trouble.
