Results 1 to 14 of 14
    Apr 2018
    Downriver,Michigan
    147
    I just installed......
    a KHZ motor mount with the larger bearing. Am I remembering correctly, some of us need to shorten our mesh adjuster screw? It's bottoming out. Might need to take a full 1/16 to 3/32 off of it.
    Jan 2019
    SF Bay Area
    672
    Mine matched up perfectly, at least with the stock gearing (which will be getting changed).
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
    RC Qualifier NitroBugg's Avatar
    May 2018
    MS
    260
    I still use the stock screw on both of my rigs, and both have KHZ mounts. Never had to shorten the screw.
    Make sure you are using both the split and flat washer.
    Apr 2018
    Downriver,Michigan
    147
    Yep, both washers are on there. Its a knurled stainless steel screw,correct?
    Feb 2010
    Indianapolis
    14,174
    King Headz motor mounts are exactly like the stock piece. If you are talking about the Hot Racing motor mount then you do have to modify things.
    Feb 2002
    9,352
    I have a KHZ, honestly, don't remeber what screw is in it. I have tons of spares, and if one is too long, I find a shorter one
    13,498
    Such as? I donít remember modifying anything for install. Direct fit for me.
    Apr 2018
    Downriver,Michigan
    147
    It was a direct drop in except for that single screw. Its a nice piece. I thought I remembered reading somewhere that folks needed to shorten up that screw. It's not a problem, just looking for conformation.
    13,498
    Did it not come with the screws?
    Apr 2018
    Downriver,Michigan
    147
    Nope,no screws. The part and 2 bearings.
    Feb 2018
    555
    Iíve bought two and they both needed the motor screw to be shortened.
    Apr 2018
    Downriver,Michigan
    147
    Quote Originally Posted by ati View Post
    I’ve bought two and they both needed the motor screw to be shortened.
    Kingz Head or Hot Racing?
    Feb 2018
    555
    Quote Originally Posted by Workingstiff View Post
    Hot Racing. I bought it because of the o ring but I have recently discovered that it is a reason to not buy it.
    Jan 2019
    SF Bay Area
    672
    Exactly
