Thread: Speed run help
    Jun 2019
    159
    Speed run help
    Mamba monster x esc, castle 2650, 18/54 gears, xo-1 diffs, and 3s. Iím running badlands tires and a stock body til the flow tech comes in. Iím running the truck on the straight away of a high school track that is rubber coated... this setup is just as fast as my 15/54 velineon on all the same as above specs. I kinda expected it to be faster? Maybe 300í isnít enough room to stretch out 18/54? Thinking I need a 4s too for the castle setup.
    Feb 2018
    567
    Quote Originally Posted by calebgilmore View Post
    Velineon has a higher kv. The 2650 will be slower until you hit higher voltages.
    Jun 2019
    159
    Think Iím going to get a 4s battery and step up to a 21 tooth pinion and see what happens. Iíll stick the 18 back in for bashing. I have a temp gun coming too.
    Dec 2017
    North Texas
    626
    Those tires and body are at their limits already.
    Expect lots of blow overs going faster.
    Jun 2019
    159
    Quote Originally Posted by LibertyMKiii View Post
    Yeah I have a flo tech body coming. I was hoping the tire growth would help a little at speed with the gearing. I should try with the stock tires maybe Iíve experienced a couple blow overs already as you can tel by the gps/truck top Hahahaha.
    Dec 2016
    198
    The 2650 is a beast on 6s
    Iíve never ran it in a Slash, but I have a speed car that eats with that power plant
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,081
    You can gear that 2650 up alot more before seeing much heat. I would go with a 24/50 before even bothering with 4s.
    Jul 2018
    156
    You need to gear higher
    I ran 23/32, 2200kv, 6s, belted grp tires, 95mph.
    Sent from my SM-G955U using Tapatalk
