    Apr 2019
    60
    What weight shock oil do you guys recommend? How much does it take
    Looking to replace oil in my shocks. What weight oil is recommended and how much oil per shock? Team associated any good?
    Nov 2018
    Spokane, WA
    373
    1 oz per shock thatís half a bottle
    I like mine stiff so itís at 70 front and 100 rear
    Team associated or team Lodi are both good choices
    15,251
    I'm running 45 front and 60 rear. I believe it takes more than 1oz per shock. I buy losi 4oz big bottles of oil, and 2 shocks use 2/3 of that 4 oz bottle. It's closer to 1.5 oz. Per shock. 1 2oz bottle per shock, and you'll have some left over.
    Edit: just remember if your gonna go up in oil weight drastically like I did, you need to go up in spring rate too, or handling will suffer. Im using the 1.4 springs with r45wt in front and 1.5 springs with 60 wt in rear
    Ya can't polish fertilizer...
    Apr 2019
    60
    Would I be able to keep stock springs and do 50k weight all around? 30k all around is stock right?
    Oct 2016
    4,382
    Itís not 30k. Just 30 or 50. I run 60 all Around with 1.4 spring in the front and 1.5ís on the rear. For a heavy truck Iím impressed
    15,251
    An economical approach:
    Pick up 1 set of 1.5 springs for the rear, and change rear oil to 50. Don't touch the front.
    I've ran that setup and it works well for a stock truck. As long as your not skying it
    Feb 2017
    UK
    568
    I also use Team Associated.
    60w rear with 1.5 springs
    50w front with 1.4 springs
    https://www.youtube.com/iftibashir
