Results 1 to 2 of 2
    Mar 2015
    raise up the rear end
    I have slash 2wd with LCG chassis. The rear end dips down, so the front sits higher. I would like to raise up the rear end so that it sits up a little higher.
    Appreciate any ideas on what parts will be needed.
    Aug 2015
    456
    Use spacers on the shock springs or get stiffer spring, also if you shocks are more vertical will give you a little more height. If your rear bearing carriers have two holes for attachment to the lower arm use the upper hole.
