Page 2 of 2 FirstFirst 12
Results 41 to 69 of 69
  1. #41
    Jan 2019
    SF Bay Area
    719
    Quote Originally Posted by Dakratfink View Post
    I love seeing this project progress.
    I do have one question about backslashes in general.
    Do a lot of people race them in 1/8 buggy classes, or do the majority of people build these for bashing ?
    Squeegie, if I remember correctly, uses his for speed runs & bashing. The one I've been collecting parts for will be used for 1/8 eBuggy racing. I should mention mine will be based on a Rustler 4x4, not a Slash 4x4...just think of it as a shortened-wheelbase BackSlash.
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
  2. #42
    Jun 2014
    Southern California
    7,577
    Mine were for bashing and ‘street’ runs... not ‘speed’ run.
    I have no place to run it for that.
    I do have most of the parts to do it if I wanted to though...
  3. #43
    Jun 2019
    176
    Mine were for bashing and Ďstreetí runs... not Ďspeedí run.
    I figured it will have better aero and none of the parachuting/trying to rotate into flight so it might run a little faster. I may leave the first body clear to bash with it some tomorrow Hahahaha. I need to practice my paint job before I go for it too.
  4. #44
    Jan 2019
    SF Bay Area
    719
    I was close...close enough for "government work"...lol
  5. #45
    Jun 2019
    176
    Thought Iíd power the backslash up and run it into everything in the apartment this morn, and the receiver wouldnít power up. It just flickered a red light every so often wasnít sure if it was the esc or receiver, so I plugged my esc in off the sand paw slash to see if it would power it up and same thing. Thinking the eBay receiver is trash on the bright side I got the hobbywing setup in the sand paw slash, just waiting on the stampede receiver box to come in to mount up front
  6. #46
    Jun 2019
    176
    Got the sissy bar and paint today! Also got the receiver box for my hobbywing slash and got it back together. Now to order the Tekno 17mm adapters and another receiver for the backslash.
  7. #47
    Jun 2017
    365
    Is that lexan paint?
  8. #48
    Jun 2019
    176
    Quote Originally Posted by alexsasax View Post
    Not sure, but Iíve painted plenty with model paints and so far so good. I scuff the surface and back with a heavy paint/primer. This being candy Iíll back with some silver and then the pro line black paint.
  9. #49
    Jan 2019
    SF Bay Area
    719
    Technically, Auto Air Colors is not a Lexan paint...it is designed for automotive use. However, it CAN be used on Lexan, and holds quite well. It is made by Createx, just as Wicked Colors is made by Createx, and is also excellent for user on Lexan.
    In regards to Pro-Line paint...it, too, is Createx. When you buy Pro-Line paint, you're buying the same Createx Air colors, just with a different label, and work a limited selection of color choices (from the full Createx line of colors). Both companies readily confirm that Pro-Line paint are actually Createx Air. Whether you buy "Pro-Line", or "Createx", you're getting a top-quality paint.
  10. #50
    Jun 2019
    176
    Quote Originally Posted by Panther6834 View Post
    Iíve used pro line, createx, vallejo, alclad II, and spray paint and havenít had any issues, but I also donít expect the bodies to live a long time as a basher. I duct tape the body mount spots on the inside and where the side bumpers/wheels might rub. I have yet to have paint flake off or fail from body movement, mine always gets worn down from friction or in the back from my gravel road. I have some Senton bodies Iíll probably run even as a cheap backup
  11. #51
    Jan 2019
    SF Bay Area
    719
    Quote Originally Posted by calebgilmore View Post
    If you read what I said, I wasn't saying the paint wouldn't work...I said it WOULD work. alexsasax asked whether it was Lexan paint...I simply explained that, while it isn't, technically, "Lexan paint", it works on Lexan extremely well.
  12. #52
    Jun 2019
    176
    I know, I didnít argue that, I was more backing up that most everything Iíve tried has worked for me so far.
  13. #53
    Jun 2019
    176
    Minor setback last night more in the time standpoint. I was going to practice with the paint but came home to my ď1200 pound capacityĒ shelf failing... nice how that weight claim is now gone. My bowling balls were no match for the shelf, and were all on top of my backslash but I donít see any damage
  14. #54
    Jan 2019
    SF Bay Area
    719
    Time to replace plastic shelving unit (or units, since it looks like you have a second behind the first) work metal units. Check Costco.
  15. #55
    Jun 2019
    176
    Iíll probably have to order one. Our Walmart has a metal framed shelf but the middles are particle board. Thankfully the back one is just full of model kits so nowhere close to the same load. Iíd check Costco if we had one Iím in BFE
  16. #56
    Jun 2019
    176
    Got the new receiver in today, and now changing from the hot racing 17mm hubs to the Tekno ones for the M6 drive shaft. It seems like itíll be a stronger piece than the hot racing sitting on 12mm hex hubs.
  17. #57
    Jun 2019
    176
    Got the parts I could on the backslash and will start working on my paint job tomorrow probably. In the meantime I converted my senton into a typhon minus the tires til the axles come in, and got another new addition to the garage above the two buggies
  18. #58
    Jun 2019
    176
  19. #59
    Jun 2019
    176
  20. #60
    Jun 2019
    176
    Got the backslash out for itís maiden voyage today and it was a blast! The paint really pops in the sun and the different tones make it look killer! I managed to power slide into a light pole and knocked the bottom plastic piece off the shock on the back left but I was able to put it back together. Other than that the wheelie bar dropped down once so I pulled out the screws and added loctite to keep them tight
  21. #61
    Jun 2019
    176
    I should mention I cut the vents open on the body, and ran the hot racing dust cover since the gravel tends to lock up fans on me when it gets kicked up inside
  22. #62
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,134
    A zip tie in the middle of the wheelie bar will stop it from dropping on u. Does require a new zip tie if you want to change position but a cheap fix imo.
  23. #63
    Jun 2019
    176
    Quote Originally Posted by zedorda View Post
    Right on, Iíll slap one on it next time I mess with it. Ripped the esc off the receiver box lid on my typhon hybrid Iím messing with now. Itís been a busy weekend working on these! Iíd like to step up to the 1/8 scale motor setups for the backslash but I need to find a place to mount the receiver. May have to leave it out of a box and avoid water.
  24. #64
    Jan 2019
    SF Bay Area
    719
    Looks FANTASTIC!!!
    LUV the color. Now I'm wondering what it would look like work the same coloring technique, but using blues, instead of reds/rusts.
    Regarding using Loctite on the screw for the wing, as long as it's not screwed into plastic, it's good...BUT, if the screw goes into plastic, that's a bad thing (ie. only use Loctite on metal-to-metal).
  25. #65
    Jun 2019
    176
    Looks FANTASTIC!!!
    Iíve used loctite on the shock screws into the plastic and it seems to hold better. Might not have been the wisest idea since it rips the shock apart but the 2 shocks Iíve smoked came apart in the middle instead of on either end. The shock cap stayed on the tower and the bottom connector this time when it was ripped apart.
    You can do the same if you have a candy blue. I should have taken pics at stages but I didnít. I did play around on the other buggy body to see what color worked best under the red. For my application I put several light coats of the red on, then I used alclad 2 chrome paint paying attention to body lines to put more where I wanted highlights and less where I wanted it darker. The back was going to fade out a little darker but I like itís still red. After that I backed the whole thing in pro line black. If you go straight to black it was kinda cool like a black cherry color.
  26. #66
    Jan 2019
    SF Bay Area
    719
    Thanks for the info. Will use that for the Tundra SCT body that'll go on my Sl4sh chassis.
  27. #67
    Jun 2017
    365
    Agree, newer use Loctite for plastic parts.
  28. #68
    Jun 2019
    176
    The velineon setup I bought for the backslash seems a little sluggish, I figure from the bigger tires. Think I should gear down from 13/54 to 11 or get a different 1/10 setup? I saw the hobbywing max10/3200kv setup is around $100 and so is the arrma 3s BLX system on jennysrc and it flat moves in my typhon. That might be a taboo move like LS swapping a Ford
  29. #69
    Sep 2015
    S.E. Michigan
    1,134
    Tire glue/CA glue for metal in plastics and Loctite/threadlocker for metal in metal is how I do it if coming loose is a problem.
