Results 1 to 11 of 11
    Oct 2018
    Southern CA
    70
    My Proline FloTek body just looks off...
    Photo of the Slash
    So basically, the body seems to have some fitment problems with the front wheels. The front wheels don't match up with the fender. It still rides okay, but it just looks off. The second problem is the look of the stance with this body. When I have the body on, the wheels appear to be too inward and the fenders stick out too far. Is there any way that I could use longer front axles to widen the stance? Any help is really great!
    Nov 2018
    Spokane, WA
    345
    I believe that body meant to be used with any 1/10 2.8 tire size
    Jun 2017
    361
    That thing will fly very nice
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,069
    The "Flo-Tek" bodies are not supposed to fit like that but if you got the "Monster Fusion" body it would.
    Flo-Tek body: https://www.prolineracing.com/bodies...clear-body.asp
    Monster Fusion body: https://www.prolineracing.com/bodies...clear-body.asp
    Nov 2018
    Spokane, WA
    345
    Yeah that looks like that monster one your should def get the 2.8 tires
    Mar 2004
    N. Idaho... Da Sticks!
    7,601
    Quote Originally Posted by Overpowerxmaxx View Post
    Not at all... That body was meant for standard 2.2/3.0 wheels and is made for racing. There are areas in the body that are made to be cut out to reduce parachuting.
    For the OP...
    How did you line up the body to the chassis before punching the body post holes? If you used the pre-dimpled body post holes that are on the body, it will be off. Proline bodies are notoriously bad when it comes to the body post marks.
    Jun 2017
    361
    @Greatscott
    Isnít that monster fusion body? It seems to be much bigger than standard sct body.
    13,529
    Looks like the Monster, designed for running with 2.8" MT tires:
    Length: 22.3" (565mm)
    Width at doors: 10.3" (260mm)
    Width at fenders: 13.3" (337mm)
    Height: 5.5" (140mm)
    Wheelbase: 13.0" (330mm)
    Regular:
    Length: 21.5" (546mm)
    Width: 9.3" (235mm)
    Height: 6.0" (152mm)
    Wheelbase: 12.7" (323mm)
    Oct 2018
    Southern CA
    70
    Quote Originally Posted by Greatscott View Post
    For the OP...
    I really just want the stance to be wider. The wheel wells aren't horribly off.
    Oct 2018
    Southern CA
    70
    Well, I already bought a full set of brand new 2.2 SC tires. Looks like I'll be selling the body
    Sep 2015
    S.E. Michigan
    1,069
    For the OP...
    You just have to look at the hood to see the difference between the Flo-Tek and the Monster Fusion bodies.
