    Sep 2019
    Fort Lauderdale, FL
    3
    Stampede 4x4 became front wheel drive today, help?
    Iím new here. Maybe I didnít hit on the right words in my search.
    Anyway one of the rear wheels turns freely by hand while the other one seems still attached to the drive train since it wonít rotate freely past a point, which I assume means thatís not the broken side?
    I am mechanically inclined but donít know Jack about these trucks. What seems to be broken? Where or what do I disassemble first? Is there a particular brand other than Traxxas to replace it with?
    I apologize in advance if this is somewhere on this site as nauseam.
    Thanks
    Sep 2019
    Fort Lauderdale, FL
    3
    Also just tried holding front wheels off the ground and hitting the throttle. There is no real pull from the rear wheels when I did this.
    Dec 2017
    Van. Island British Columbia
    834
    Check to make sure the screw pins that hold the axle to the diff are in sometimes they fall out, that's usually been my experiance when one set of wheels don't spin.
    Dec 2016
    Burleson, Texas
    234
    I would say pull off the rear wheels and see if the hexes have rounded.
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    Nov 2018
    Spokane, WA
    301
    You might of messed up your differential
    Sep 2019
    Fort Lauderdale, FL
    3
    Took the offending wheel off, have a few questions
    Thanks for the input gents! Wish I could post pics w/o a host site (which I donít have).
    The inside hub of the wheel apparently is rounded off. Looks like itís supposed to be hex shaped to fit over the inside drive but.
    1. Would this cause the other side (same axle) to not drive at all?
    2. Is this a common problem? Did did the outer nut (locknut) somehow loosen up?
    3. Anything I should do different, or buy to prevent from happening?
    Nov 2018
    Spokane, WA
    301
    But Aluminum wheel hexes
    Dec 2016
    Burleson, Texas
    234
    1) Yes
    2) Yes. Usually the nut will losen up and the wheel comes off a bit letting things round out.
    3) I use these and haven't had the issue since: Traxxas-Blue-Anodized-Aluminum-Flanged-Serrated
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,011
    17mm hex FTW.
