Results 1 to 19 of 19
    Dec 2018
    34
    Wheel kept falling off
    The front left wheel kept falling off from my slash 4x4. The first time was yesterday morning, it falled off when the car was running. I bought some wheel nuts https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and put the wheel back and made sure the screw was secured. Tonight, the same wheel falled off again when I was running it. Any body kown why?
    Aug 2015
    457
    Is it a nylon locking type wheel nut?
    Sent from my VS996 using Tapatalk
    Aug 2019
    Staffordshire UK.
    23
    As above nylock nuts should not unscrew them selves.
    Jul 2017
    239
    The wheel hex could be stripped and the axle shaft will rotate in the wheel and unscrew itself. I've had that happen
    Mar 2018
    49
    Or pin is too short and nylon cant bite into it. Medium threadlocker will fix it ;-)
    Feb 2002
    9,352
    Get steel nuts. The aluminum is not oe spec
    Mar 2004
    N. Idaho... Da Sticks!
    7,572
    Quote Originally Posted by jimbo74 View Post
    X2.
    Also, make sure the threads on the drive shaft are clean. If you have any kind of oil on there the nylock will not lock well.
    Jan 2019
    SF Bay Area
    676
    Zooming in on the photo, the hex looks pretty smoothed-out...no defined edges, along the sides, as well as the 'flat'. My guess is, the nut isn't the problem (or, at least, not the only problem). Time to replace the hex, itself. As mentioned, if the hex is spinning inside the wheel, it could cause the nut to undo itself. Of course, also as mentioned, if the nuts being used are all-metal (steel or aluminum), you NEED to use Blue Loctite to hold them into the axle stub.
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
    Dec 2018
    34
    My nut is nylon.
    What is the part number for the hex?
    Dec 2018
    34
    I guess other wheel hex on my car has similar worn. Should I replace them too? Is the torn hex going to impact the speed?
    Jan 2019
    SF Bay Area
    676
    I'd suggest replacing the plastic hexes with aluminum ones, on all 4 corners. Even better, you might consider getting the Tekno 12mm clamping hexes...a little extra $$, but worth it. AMain carries them for $18, and they work perfectly work Traxxas (and other brand) wheels.
    13,500
    Yes. A stripped hex will spin in the wheel and all the power to that end of the truck will want to unload in that direction (path of least resistance).
    Feb 2010
    Indianapolis
    14,177
    Looking at the picture, the hex isn't that rounded. I would out either a drop of Loctite or super glue on the threads and let it sit for at least twelve hours.
    Dec 2018
    34
    I replaced the hex with this one https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 , however, the wheels still fell off. Why?
    Jul 2017
    239
    The hex in the actual wheel could be stripped out possibly. Only thing I can think of
    Dec 2018
    34
    I rotated the wheels. But still, the front left fell off.
    Dec 2016
    Burleson, Texas
    235
    I don't see any hexes on the hub. Also, lets see a pic of the nuts you're using and the back of the wheel.
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    Jan 2019
    SF Bay Area
    676
    Hex photo from the side that goes against the wheel, that is.
    Sep 2017
    110
    Quote Originally Posted by gecong View Post
    You might want to take one of your other wheels off to see what they’re supposed to look like. Looks like your missing the pin that the hex but sides into to keep your spindle from retreating.
