Results 1 to 11 of 11
    Jul 2019
    51
    Gearing... Again.
    Alright guys so gearing gives me headaches. I want high top end speed but still enough low end to bash fairly decent. I'm thinking about switching to 48p but, should I go 12/62? Is this the ballpark I want to be in? I know a lot of guys say well test it out and see trial and error type thing. Which I've tried a little moving the pinion up and down but I've stayed with the same spur gear.
    Sent from my LG-US998 using Tapatalk
    May 2017
    104
    Is your slash brushed or brushless?. If it is brushless I would go with a 54 metal spur gear from Robson racing, with a 14 tooth hardened steel pinion. I find that gearing to be the best for bashing cause lots of acceleration and top speed. (be careful about temps when you re gear your truck) if you are brushed, I highly recommend you go to brushless and with cooling fans better for bashing.
    (saying brushed cause u said maybe switching to 48p the brushless modes use 32p)
    604Slash4x4]
    GoneBashing
    Jul 2019
    51
    Quote Originally Posted by 604Slash4x4 View Post
    604Slash4x4]
    GoneBashing
    Actually I have the hobbywing max 10 esc with the 4600kv motor
    Jun 2017
    437
    If you are using 3s battery, with such high Kv motor, I would start with biggest spur and smallest pinion gear.
    RC Racer gusd2's Avatar
    Jan 2015
    136
    Quote Originally Posted by TheBasher01 View Post
    It would help to know what “top speed” you’re looking to achieve. The 14/54 combo suggested is good for about 30mph on 2s and closer to 50mph on 3s (theoretical).
    To keep temps down, you may need to consider a lower KV motor.
    Jul 2019
    51
    Quote Originally Posted by gusd2 View Post
    Everyone's recommend that I get a lower kv motor but the truck doesn't need that much torque as it is the truck does wheelies I need to find a gearing ratio that can move the truck faster I was thinking going up in size on the spur gear.
    I'm running 12/54 mo.8 right now. Yes the truck is fast but you can never be too fast. I'm thinking 12/62 would push me where I'd like.
    Jun 2014
    San Gabriel, California
    8,474
    Wouldn't 12/62 be lower top speed and higher torque?
    Speed needs a larger pinion and a smaller spur...
    Jul 2019
    51
    Should I bring it to 19/62?
    14,229
    You are correct. Needs to go smaller on the spur or bigger on the pinion.
    Don't want to go to big of a change; assuming you have VXL diffs: 14.725 final gear ratio going down to 9.30. You'll kill down low power and heat up the ESC.
    Play around with the ratio: (spur gear/pinion) x 2.85 = final gear ratio.
    Jul 2019
    51
    Yes I have the vxl diffs and the stock driveshafts maybe I'm just lucky but I beat my truck and I've never broke a driveshaft yet. But in theory it's a vxl slash with a hobbywing heart
    Jun 2017
    437
    Actually I recommended smaller pinion to avoid heat problems. What battery do you use in your Slash?
    I have same setup with 3200kv HW motor and it is really fast on 3s. Gearing is 16/54.
