    Feb 2019
    41
    Angry how to use stripped rim tires
    i have a traxxas slash 2wd with mip xdutys and i strippef the hex in the rim
    i cant glue the hex from the rc into the rim because the hex on the mip xduty driveshafts has to screw in so how can i use them they are still new anything thanks
    Jul 2019
    Boston
    130
    Quote Originally Posted by lukebush16 View Post
    You might be able to get away with using an epoxy putty to create a new female hex opening in the wheel. Pack it in there nicely, wait for it to harden fully, and then dremel it out.
    I used it in a similar fashion on some tamiya wheels that were degraded by the misuse of loctite. It lasted for about a year.
    Feb 2019
    41
    i dont have a dremel
    13,498
    Don't liberally apply the epoxy and use a knife to cut away the excess. Or wrap the hex in aluminum foil, put epoxy in the rim and press the hex in. When it dries remove the hex and clean up.
    Feb 2019
    41
    Sep 2019
    Tehran
    How long have you used this fix? how does it hold up?
