    Sep 2019
    3
    NEU 1110/1y vs Castle motors?
    Hey everyone, I am new to this hobby and looking for the highest quality and longest lasting motors to upgrade my stock brushless vxl 380 vileneon motor.
    How does the (black) handmade NEU 1110/1y compare against the Castle Creations 4600kv or 5700kv motor?
    This will be paired with a Mamba X ESC. Unless you can recommend something better.
    Dec 2016
    N Dakota USA
    502
    Quote Originally Posted by iKO View Post
    I don’t have much experience with upgrading the drive train in the 1/16th. I have the stock velineon motor with a Losi ESC in my mini revo and I love it. The stock 380 in the vxl system is pretty decent, quick and reliable.
    That said I have hear a lot of good about Castle systems
    Sep 2019
    3
    Quote Originally Posted by Dakratfink View Post
    The only problem with the stock 380 is that it gets very hot, especially while using Lipo batteries. And I wanted to run a single 3s battery for good speed and torque. I have been reading a lot on the forums but these are posts from years ago regarding motor comparisons.
    I was hoping somebody could chime in and inform me of what is the current "best of the best" setup scenario in terms of a motor/ESC combo to date. Technology always gets better over time and from reading old posts it seems like the Castle motors or NEU motors were king.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,128
    I have the "big block" version of the MERV so it has the brushed 550 motor same as the Slash/Stampede line. With all the extra 12T Titan motors I have that only cost about $12 each I will likely never spend as much as one brushless setup in it's entire lifespan. It can do all the wheelies/stoppies and insane jumps but without blowing out rear diffs or the need of shims ever. I can't understand the want for brushless in the MERV. The only upgrade to the electronics I have done was swapping the stock XL-2.5 for the XL-5 from the heavier 1/10th scale line. Again which I have a surplus from all the brushless systems I have in my larger Traxxas vehicles.
    Oh yeah forget I did buy a new servo when the stock one broke a gear.
    I think each time I started planning upgrades for my MERV. I ended up seeing the cost and just bought a larger 1/10th RC since what I was trying to do was upgrade to 1/10th performance anyway.
    Sep 2015
    S.E. Michigan
    1,128
    With that said if you are still dead set on going brushless. I highly suggest doing the "big block" upgrade so you can run a Castle 1406 motor.
    What I would suggest.
    http://www.castlecreations.com/en/si...or-010-0164-01
    The Mamba X is way more than you should need but here is that version.
    http://www.castlecreations.com/en/ma...bo-010-0155-01
    Sep 2019
    3
    Could I not use a NEU 1110/1.5d and Mamba x with a 4s battery? Obviously I would need to upgrade all of the suspension.
    Otherwise I just save up and instead of upgrading my 1/16 E Revo I get the 2.0 Revo
    Apr 2019
    With that much power you may need to shim your differentials and go with steel driveshafts or be really easy on the trigger. I run a Velineon 3500 with Mamba X and ended up doing it all.
    Sep 2015
    S.E. Michigan
    1,128
    All I could find about the NEU 1110/1.5 is it is for aircraft which are very light weight so I can't see it being usable in a surface RC without burning up. This is an assumption but based on what I have learned about RC motors says there is a reason there is a distinction between the 2 but I have never tried it.
    Sep 2015
    S.E. Michigan
    1,128
    I did find this thread about that motor in a MERV.
    https://forums.traxxas.com/showthrea...110-1y-problem
    I believe this is an example of the motor burning up over a short lifespan of not even heavier duty use.
    EDIT: Not sure why it double posted when i added the link, sorry.
