Page 2 of 2 FirstFirst 12
Results 41 to 46 of 46
  1. #41
    Sep 2019
    22
    Where do I plug in my transmission? I think it went into the Optidrive before. I have throttle and steering functioning, thanks.
  2. #42
    Dec 2014
    Adirondacks
    450
    You don't need to plug in the transmission sensor. The sensor tells the opti-drive module when it is ok to shift. Without having the opti-drive module there's no need for the sensor.
  3. #43
    Sep 2019
    22
    So how do I turn this thing off when the body is on? I tried pulling the the fuel filler cap up to stop it from pumping fuel, didn't work. Had to take the body off and pinch a fuel line, that can't be right.
  4. #44
    Dec 2014
    Adirondacks
    450
    Quote Originally Posted by DoubleJ View Post
    It is.
    Or you could get a bumble-bee-nitro-kill-switch
    Or plug the exhaust. If it still has the rubber exhaust extension/deflector you could squeeze that to kill the engine while the body is on. Be careful though as the exhaust is hot.
  5. #45
    Dec 2003
    Dekalb, IL
    2,513
    I usually just reach under the body and touch the flywheel with my tuning screwdriver handle. Plugging the pipe works, but it also has a tendency to shove a lot of excess fuel into the engine which makes it annoying to start the next time.
    Expert rigging at it's best!
  6. #46
    Dec 2019
    (There are two grey rings...) and now I've got a no-starter. Nothing at all, won't even make a pop. The starter is also slipping off it's gear like crazy.
