Results 1 to 22 of 22
    RC Enthusiast gandalfnz's Avatar
    Sep 2019
    New Zealand
    35
    Please tell me how well tuned my Nitro Slash is? - VIDEO
    Hi
    I am having overheating issues with my Nitro Slash
    HSN is half a turn closed from factory break in settings (so 3 and a half turns out).
    LSN is half a turn out from factory break in settings as well.
    However driving the car like this, the temp went up to 280 and the engine just stopped and there was white smoke coming out from the cylinder head.
    Car still works great and runs well on idle, I would just like to avoid overheating it again.
    I am new to nitro RC's.
    I have attached a video of the car running.
    How does it sound to you guys?
    Thanks for your support.
    https://1drv.ms/v/s!AuKPb81w0u47lFfz...9XMBw?e=zk9e1F
    Dec 2016
    N Dakota USA
    780
    I’m a relative noob when it comes to nitro, but it sounds alright to me. The temperature and cutting out is concerning though. I would maybe riches it a bit, just to be swept cool it down. And keep an eye on the temps. I don’t think you did any damage though. Hopefully someone with more tuning experience will give us both some advice
    Sep 2019
    New Zealand
    35
    There is no pinging at all that I could hear? Maybe the video makes it so.
    Plenty of blue smoke.
    Transitions from low to high really well but overheats.
    Idles great too, heres a video of it idling when started from cold.
    https://1drv.ms/v/s!AuKPb81w0u47lFLZ...IcuEU?e=KyKAkP
    Maybe I should richen both needles a bit?
    Dec 2014
    Adirondacks
    1,148
    In the first video, sounds good in the short time of the video. If the engine cuts out from overheating, richen the HSN and tune again. If you get back to the same settings, try with the body off and see if temps go down. It also could not be getting enough airflow. You might need to run a little richer for your driving style and area. I would try opening HSN 1/4 turn and try running and see how it acted. It's better to run on the rich side than lean settings.
    Looks like your having fun.
    Sep 2019
    New Zealand
    35
    Is it normal when you first start the engine to be so sluggish until it warms up. Pulling on the throttle barely moves the car and it sounds like its running super rich?
    Then when it warms up, goes like crazy!
    13,889
    The engine will be a little sluggish when cold. A good thing to do is make sure there is no air leaks and that air is only entering in through the filter and out through the exhaust stinger. Replace the fuel and pressure lines and if you have any oily residue around the exhaust parts then you have a leak.
    Many times the HSN may be fine but a lean LSN will allow the temps to creep up as the engine will not be able to cool when off-throttle. If you have a temp gun run it for a bit, bring it in and watch the temps at idle - they should be dropping a degree or two every few seconds. If they don't then richen it up a little. To make it a little more "complicated" an idle gap too big could have a lean LSN and seem okay; as well as a small air gap and rich LSN. Set the idle gap to 0.7-1.0mm open and leave it.
    Sep 2019
    New Zealand
    35
    Hey
    Many thanks.
    No oil residue anywhere on or around the exhaust.
    That is a great idea, so warm it up to around 100 celsius ( think thats around 200 Farenheit) then leave it to idle while watching if the temp drops with a laser gun?
    I have a Milwaukee temp gun, so will try this tomorrow.
    First thing I did was set the idle gap to around 1mm or slightly less. I donít touch the idle anymore but rather adjust it with richening the LSN.
    Pls click on the second link I posted to see the car idling when cold, I am thinking I still need to richen the LSN just a bit more.
    Thanks
    Dec 2014
    Adirondacks
    1,148
    Second video link doesn't work for me. You shouldn't be using LSN to adjust idle. All adjustments for tuning should be done at operating temps. Adjust, run vehicle, check and repeat as necessary. Once the tune is good you would only need minor adjustments each different time you ran the truck.
    I don't think Double G meant to say set idle at 0.7mm to 1.0mm and never touch again. The idle air gap should be in that range or very close to it when adjusted.
    As an example of what I think you are doing now is setting the idle gap at 1mm and using the LSN to lower the idle, if you are you are probably running rich at idle. Use the idle pinch test as a guide. How does it accelerate after idling for 5 seconds?
    If you need to run your LSN really rich to idle, there is probably something else going on.
    Here's a quick guide that might help http://www.rcdriver.com/basic-engine...-your-needles/
    Sep 2019
    New Zealand
    35
    Thanks for your help.
    Please check this link to see the car idle
    https://1drv.ms/v/s!AuKPb81w0u47lFLZ...IcuEU?e=dDLlgj
    It takes off really well, even after idling for 5 seconds. There is no change in sound of the engine running (loading on fuel) after 5 secs. Its a nice and constant idle.
    I am very confused when it comes to pinch test, and have done tons of reaseach on this subject.
    Do I need to do a lap, then bring the car back and pinch the fuel line asap after stopping it?
    Or, do I have to leave the car to idle after doing a lap, and then pinch the fuel line?
    Reason I ask, I did this test as soon as the car stopped and the engine shut off in about 1 sec.
    Thanks
    13,889
    I haven't touched the idle gap since I set it. I tune the HSN for smoke, performance and sound and the LSN by the pinch test and monitoring temps while idling.
    A rich LSN will allow the engine to slowly build with fuel and take off will be a bit slow and smokey until it clears out. An engine with a lean LSN will have an idle the creeps up as well as the temps. The HSN is more forgiving to tune, the LSN is pretty sensitive so small twists are necessary.
    Tuning is an art and will take a little bit to understand. If at any point you get lost or frustrated, go back to factory settings and start over. Good practice is to warm the engine up, tune when at temp and around a half tank. You'll have a slightly rich setting when full and slightly lean when empty.
    Sometimes it is better to be seen than read: https://www.youtube.com/watch?v=eP85V_QKcFo
    2 minute mark: https://youtu.be/pEGjExP9GkM?t=119
    If you can find videos by Squirrelod on Youtube then don't miss. He made some great videos back in the day but they all seem to have disappeared.
    Sep 2019
    New Zealand
    35
    Thanks for the vids.
    They still don't specify whether to pinch immediately after stopping or wait a little while and then pinch?
    I the second vid I see he leaves it running idle then pinch it, but I am not sure for how long he leaves it running idle?
    Does that even matter?
    Thanks
    13,889
    You're worried about something that shouldn't be much of an issue. Run it, bring it to a stop and pinch the line. In the seconds it takes you to bend over and pinch the engine will not load up that much.
    Obsessing over the minuscule points regarding the tune will take the joy out of running nitro.
    Sep 2019
    New Zealand
    35
    Fair enough.
    I already did this when I had the run from the video, and when pinching the line as I stopped the car, engine turned off after 2 seconds.
    Thanks
    Sep 2019
    New Zealand
    35
    Another question.
    The idle gap should be 0-7 - 1mm when looking from the top of the air restrictor or looking from the side?
    If I insert a 0.8 paper clip, should I hold it straight, or hold diagonal/from the side, when measuring the gap?
    Might be a stupid question, but gap width does change depending on the angle you look at it.
    Thanks
    13,889
    Straight in.
    Sep 2019
    New Zealand
    35
    Just a small update.
    I have tuned the car really well, it runs great!
    Starts super easy, press ezy start button for a sec or two, and idles really good from cold.
    Blue Smoke coming out
    Takes off really well when idling even for 10 seconds (LSN good). Pinch tested and shuts off at around 3 seconds.
    Engine temperature is around 230
    I must say I am loving the nitro slash, found I enjoy it more than our 4x4 electric version.
    Now looking at buying a spare engine.
    Only thing is, that 150 ml fuel tank does not last very long at all!
    Oh and I purchased the VENOM smart temp, just to play around with it, and try to get temp fail safe working. Found it cheap.
    Thanks all for your support.
    Dec 2014
    Adirondacks
    1,148
    I'm glad you got it sorted out. Sounds like your having a blast with it. .
    In case you didn't know you can refill the fuel without shutting off the engine.
    13,889
    A full gallon (3.8L) will fill the tank 25 times. Multiple the time it takes to drain a tank by 25 and you could have hours of running till the engine glows fun!
    Sep 2019
    New Zealand
    35
    But the body has to come off in order to refuel.
    Revo 3.3 has a nice feature where you can refuel without taking it off.
    Sep 2019
    New Zealand
    35
    True.
    A tank usually lasts me around 15 mins.
    Does anyone know if new Rustlers come equipped with a 3.3, or are they still 2.5 standard?
    Thanks
    Sep 2019
    New Zealand
    35
    Why isn't image posting working on the forum?
    I have mounted the venom smart temp on the car.
    Using it just as a temp gauge, and to be honest its working out better than the temp gun.
    I had to move it around, and try different locations on the cooling fins, but once I matched it with what my temp gun is showing, it now works great.
    Even more useful is the air vent cut out on the body, no need to remove the body to see the temp.
    Great!
    Pics
    https://ibb.co/NFqYVQN
    https://ibb.co/7jbVdkq
    https://ibb.co/DDrBxwT
    Dec 2014
    Adirondacks
    1,148
    Quote Originally Posted by Fleurpink View Post
    It would be if they continued to run it on a lean tune. At post #16 issues resolved and were having a blast enjoying their well tuned engine. That's what this community is for, helping each other.
