Hey guys I have a 2wd rustler and I really want to get a 4x4 model. My 2wd has the castle sidewinder sct and 3800kv motor and it is fast as heck on 3s.
Once I have the 4x4 I would like to put the CRAZIEST motor and esc combo in it as possible. Literally, I want the most powerfull motor that I could put in it.
What is the most powerfull esc motor combo? I really don't understand how the Kv/voltage measurement. As I have seen motors with half the rating (2200kv) ripping hard.
I know I also need full metal/steel drive axles. What are the best bang for your buck metal drive lines/axles?
Edited for language abuse. If you see a starred out word in your post, please edit it out to avoid earning warning points.
Get a platinum edition slash and put the
El sob special in it
It is best to plan from the battery you want to use not the motor/esc combo. And budget to goto "CRAZIEST" land what kind of budget we working with? $1000 to $2000 or $5000+ for this whole project? We also need to know the application you are going for - Bashing, Racing, Crawling, Drag, or Shelf Queen(showcar). There isn't just 1 "CRAZIEST" pick.
Here is some food for thought that might help with picking and insight to Kv ratings. Feel free to skip ahead about 8 mins to get passed the brushed stuff.
https://www.youtube.com/watch?v=BcuhdkCucGA
I semi-second this. While I'm not 100% onboard for getting the Platinum Edition, I do agree100% on getting a Sl4sh, inside of a 4pede, or Rusty 4x4. The 4pede is too tall, especially if your intention is to go as fast as possible. While the Rusty 4x4 is great (I've got 2), the clipless body system is a "problem" (almost every time you crash...especially when the crash is slightly to the left/right side (as opposed to 'straight head-on)...the front of the body pops off the front body mount). It's because of this "problem" that I've been modifying one Rusty to standard shock towers & body mounts (the other Rusty will be converted into something entirely different).
Soaking of "converting", another reason to go with the Sl4sh is the multitude of options, from different bodies & carbon fiber shock towers (ie. JConcepts Suspension Conversion Kit), to converting the entire vehicle into a Speed Eliminator (ie. drag racer, which I just might do if I get a 2WD Slash rolling chassis).
~ More peace, love, laughter, & kindness would make the world a MUCH better place
I have a rustler 4x4 and slash 4x4 lcg. I am selling ths slash as i like the rustler much more. Its more stable and the body is much better and doesnt catch air when you are jumping. Which makes it more predictable. Also if you want a rustler 4x4 i will sell you mine
The "ballooning" of SCT bodies is common. You just need to learn to accept that fact, and move forward. As for the Rusty beefing "more stable", from a scientific standpoint, that's not actually possible. Other than a few parts (front/rear shock towers, front/rear bumper, chassis, center driveshaft), these two vehicles are, essentially, identical. The biggest difference is that the Rusty is approx 1.25" shorter, which exactly why the Sl4sh would be more stable - its base (length/width) covers a larger area, thus leading it to be more stable. If you are 'hung up' on the body "ballooning" issue, you could always convert it into something else: backSlash, street eliminator, monster truck, etc.
No, the Slash does not "need" a lot of money out into it, anymore than the Rusty does. The "needs", and "wants" of both vehicles are, essentially, the same. This would be...once again...due to the fact that both vehicles use the exact same parts for the great majority of the vehicle. If you choose to upgrade something (ie. aluminum C-hubs, carriers, shocks, etc), with very few exceptions, the same parts can be used on either vehicle. With the right parts & body, plus some ingenuity, you can come very close to turning a Rusty into a 'shortened' Slash, or a Slash into a 'longer' Rusty.
I'll admit, I really, REALLY like my TLR vehicles, as well as my XRAY T4...and, I'm certain I'm going to like my new Axial Capra (once it's delivered, and I build it)...but one of the things I really like about Traxxas vehicles is the user of the same parts on multiple vehicles. For example, if you'd want a stronger drivetrain on your Slash, or Rusty, you can install the front/rear diffs and or driveshafts from the XO-1. Heck, I've even figured out a way to install the XO-1 front shock tower on the front AND rear of the Slash/Rusty.
Ok hold up you guys lost me...
Yeah I don't like the slash and its tiny little tires. I want a truck with big tires.
Alright, so do I need to get new axles for the rusty 4x4 if I throw a beefy motor in there?
As far as my price range I can go like 200 bucks on a esc and motor, I want something really powerfull but within reason...
lol I'll buy a brand new one at 375, but thanks
For tires (and wheels, for that matter), you can put almost anything you want...that goes for the Sl4sh, as well as the Rusty. The "stock" Rusty tires/wheels are 2.8", but there are several options in that area now. As for the Sl4sh (this also applies to the Rusty, if you're willing to switch to SCT wheels, which I did), there are even more options...everything from off-road tires to street slicks, as well as numerous track tires for dirt/clay & carpet. I won't say the choices are "endless", but it's pretty close.
As for replacing the ESC & motor (again, for the Sl4sh, as well as the Rusty, as both vehicles are, essentially, the same), if you check out AMain's website, you'll find no less than 47 ESC/motor combos currently available for under $200. Additionally, if you can add a little extra, you'll find 14 combos in the $200-215 range (3 of which are on-sale for $210, normally $235-250). Among there are several Hobbywing Justock, Hobbywing Xerun, Reedy Blackbox, including several that use the Hobbywing XR10 Pro Stock Spec (2S only) & XR8 SCT ESCs, both of which are excellent.
Ok well should I get a system that runs on a lower kg but runs 6s? Or should I stick to a 3s system with a higher kv??
Picking the "right" kv motor is abit of a complicated matter. Like your favorite color we can't pick that for you. It highly depends on how you like to drive and what surfaces you drive on and what battery you want to use and the speed you plan to be driving at. Lower kv motors tend to be used in heavier vehicles on rough off-road terrain with less traction. While higher kv motors tend to be used in lighter vehicles on hard smoother on road high traction surfaces. Also kv isn't in direct relation to torque or horsepower, a better comparison would be can diameter = torque and can length = horsepower but even that is not exactly correct but a generalization.
Since I am planning on replacing the motor and esc almost immediately, should I just buy the basic non-vxl 4x4 rustler? and save almost 100 bucks? Does that have metal gears and the same chassis?
I am thinking of getting a castle mamba with a 2200kv motor and running one 6s battery.
That would rip pretty good right?
It worth buying the vxl system and then sell it on here for 100 bucks the vxl also comes with tqi radio instead of the tq model as well as the better looking imo body
Okay,
I am looking at putting a Arrma Kraton BLX esc and 2050 BLX motor into the rusty 4x4.
How fast/powerful would that be on 4s? 6s?
Plug the basic stats here and it can give you an idea of where you are at with speed, etc.
https://scriptasylum.com/rc_speed/top_speed.html
I don't buy into selling parts off new units. I buy the lower one and upgrade then use the removed electronics in other vehicles. I have found owning lots of spare parts fixes many issues in other projects a whole lot cheaper.
I own a 2wd Slash lcg, 4wd Slash lcg and 4wd Stampede. If I were to do it again I would only own a 4wd Slash. I don't run in terrain where the Stampede is needed and it likes to wheelie a lot so I found it somewhat annoying. The Slash 2wd is nice but the 4wd is just...better. My opinion of course.
The Velenion isn't a bad system but I burned up my motor and have been in the process of putting in a Castle Monster X and 2650kV system for about 3 weeks now (having some issues with it) so it should be a lot of fun once I get done.
Scott
Slash 2wd
Slash Ultimate 4wd
Stampede 4wd
I am pretty sure they are the same but haven't owned a new 4x4 rustler yet but for the most part the main difference between the XL-5 and the VXL model for Traxxas is just the Velineon system and possible TSM or OBA. You can check the parts lists or the exploded views of each to find out for sure.
What is TSM and OBA
TSM = Traxxas Stability Management and OBA = On Board Audio
We're not sure what's up. I sent it in for repair and it worked fine for them. Got it back and it was good for about 30 seconds then started freaking out gain. I would say this is probably a rare occurrence because I've never read anything negative about their stuff.
As far as other systems I really can't comment, I'm not that experienced with aftermarket stuff.
Scott
Slash 2wd
Slash Ultimate 4wd
Stampede 4wd
With the exception of the 2wd slash, choosing xl-5 usually means:
-motor and esc, obviously
-nonadjustsble camber links and turn buckles
-2056 servo versus the “better” 2075.
-plastic center driver shaft versus aluminum on the vxl, for 4wd
-no stability control
-you lose the ability to bind multiple vehicles to one controller with tq
-lower diff ratio for 4wd
-bushings instead of bearings for 2wd stampede, rustler, and I think bandit
-philips screws instead of hex screws for 2wd stampede/rustlers
Etc
I would never recommend anyone getting the xl-5 to save money, if one wants to upgrade they are better off buying vxl rollers to start.
Since he wants to put in a much more powerful motor, is it really that that unhelpful to provide him as much information as possible so he knows and can decide for himself if he wants to live with the downgraded hardware on xl-5 model? You said the main difference is
“ Velineon system and possible TSM or OBA. “
I‘M saving him some time since you also said to
“check the parts lists or the exploded views of each to find out for sure.”
If the info I provided is so unhelpful, you are free to point out what I misstated or got wrong.
Did I say at all you were not helpful? It was just quite snarky and you didn't have to reply to me. It only adds animosity. You literally hammering me for being wrong on a guess. Which I made clear with "I am pretty sure they are the same but haven't owned" and "for the most part the main difference between". I didn't say it was a fact or that I own it and know it for sure.
