    Oct 2019
    Best all around tires for XO-1?
    So basically this is my first real RC car so I don't know too much about modifying them. I opened my car and after about 15 minutes of driving, I blew out both front tires. I didn't crash it into anything but I did spin the tires quite a bit. I knew I would wear them out but definitely not this quick.
    What are the best all around tires to use for the XO-1? Grip itself, to me, isn't as important as the durability of the tire. will be running mostly on asphalt. Will rarely ever go higher than 60mph. Looking for a tire I that hopefully just put on without needing further modifications.
    Jan 2015
    72
    GRP 1/8 tires and wheels will fit fine. They are a bit shorter than stock but they come in a variety of hardness and therefore you can get something that will last longer but be less grippy.
    RC Qualifier kzsteve's Avatar
    Jan 2018
    norcal
    278
    try foam tires . gone bananas has many type tires ..
    XO-1 GUY GETTING OLDER BY THE MINUTE
    Oct 2015
    948
    Quote Originally Posted by Nascargavin8 View Post
    What kind of road were you driving on to blow them out? Or maybe what kind of driving were you doing? I have used nothing but stock tires for all of my driving and have never blown any of them out.
    Eastern Shore, Maryland
    4,129
    (IMO) the best (and best looking) tires are the stock ones. When I first got my XO-1 the same thing happened to me after 4 battery runs. If you do speed runs you won't have this problem, but you sound like me in that your a parking lot man...not a problem. Here's what you do.
    You run a figure eight course, or you setup a course that has the same number of right turns as left. If you do that, and use the same technique going around turns as you would a full size car, you will get way better wear out of your tires. I generally get 33 to 35 (20 to 30 minute) battery runs out of mine. I generally do the figure eight using a parking lot the size and a half of a football field. Good luck!
    Nov 2019
    3
    Where did you get your Corvette body? I can't find it anywhere.
    Sent from my SM-N950U using Tapatalk
    RC Turnbuckle Jr. vxlrocket's Avatar
    Dec 2007
    Manassas, Va
    7,181
    I like BSR foams. A lot of people go for the harder compounds like purple but i get the most traction with 25 or 30 shore or even the red compounds. For me, it's a game changer from any rubber tire I've ever used. They won't balloon either.
    One mans garbage is another mans ungarbage" -Ricky
