    Jun 2019
    22
    Bad Turning Radius
    Hey I have a 2wd rustler with a Castle 3800kv system in it.
    I have noticed that the turning radius seems to just be really bad. Sometimes it turns to the left just fine but turning to the right has almost double the radius of turning left....
    What is the deal here? I have messed with the steering servo adjustment on the transmitter and all that does is shift the inbalance to the other direction.
    Do I need to take apart the steering rods and reconnect them or something???
    Oct 2016
    4,230
    Quote Originally Posted by Cobalt172 View Post
    Rods should be the same length, servo may need to be centered. How’s your steering trim. Too far either way is an issue.
    RC Qualifier FlyingTigerDad's Avatar
    Jan 2016
    SoCal
    597
    I'm thinking bent kingpins in the caster blocks...
    Knowledge gained is lost forever if not passed on.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,061
    If all else fails check the transmission.
    Jun 2019
    22
    Quote Originally Posted by FlyingTigerDad View Post
    which one is the kingpin?
    Also why would I check the transmission? lol
    RC Racer RC Dad's Avatar
    Jul 2019
    Boston
    203
    The kingpin is the one that goes vertically through the caster block. They get bent pretty easily. I think the best solution is to upgrade to aluminum blocks.
    You could also look closely at your servo saver and make sure it isn’t banged up. I had a similar issue once, almost exactly as you describe, and the stock servo saver was about busted in half.
    Not sure about the tranny comment. Good luck!
    Sep 2015
    S.E. Michigan
    1,061
    If nothing else seems to be wrong there is a possibility you only have 1 wheel getting power. And if it is the right rear it would be hard to make tight right turns.
