Results 1 to 19 of 19
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,482
    I finally went brushless on my Big Block MERV.
    I bought one of those cheap GoolRC 540 size brushless motors that is finned with just 380 size guts. I had a Sidewinder 3 SCT esc in my spare parts bin. Which forced me to sacrifice one of the battery bays for it. At least the 2s batteries it uses are small and pocketable. I won't be able to do a full proper test till tomorrow but the little I could do around the house gives me high hopes.
    The motor I bought:https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jul 2016
    26
    Looks good!
    Sep 2015
    S.E. Michigan
    1,482
    I also switched to 7132R Rear Suspension Arm Set that adds 10mm to the wheel base. I believe these are just the rear 1/16 Summit arms. One kewl thing I noticed as soon as they were completely installed. They move the rear wheels out of the way of the battery bays.
    The arms I bought:https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Next addition will be Duratrax Bandito ST 2.2 Tires on JConcepts Rulux Rims. Hopefully they aren't too tall I couldn't find the OD measurement for the tires in the ST style but I think they should be around 3".
    Sep 2015
    S.E. Michigan
    1,482
    Received my Rulux rims and Bandito tires and glued them up into wheels. I think they are just the right size but not real heavy like most 1/10th rim/tire combos some try to use.
    Tires pictured: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Rims pictured: https://www.jconcepts.net/shop/rulux...wheel-22-black
    Jan 2018
    129
    When you added the rear Summit arms was there any other parts needed? Like the push rod & toe links.
    May 2006
    Murfreesboro TN
    350
    Nice swap over, I'll be one to say dont sneeze at some of the "Cheapo" things there are, bought a Hobbywing 120A ESC to throw in my slash and it works great, also grabbed a Readytosky 2.4ghz radio system too.......amazon ftw
    Sep 2017
    San Francisco, CA
    55
    I made a bracket for the esc that slides into the stock location. I made out out of angle aluminum from the hardware store. You have to mount it sideways but still fits in the body.
    https://imageshack.com/i/pnoXlEmLj
    Jun 2014
    San Gabriel, California
    8,562
    Quote Originally Posted by Black-n-red View Post
    No other parts necessary.
    I did it to my MERV 6 years ago and haven't had a problem!
    Jan 2018
    129
    Thanks for the reply. Iíll be ordering some here shortly.
    Sep 2015
    S.E. Michigan
    1,482
    Thanks for the reply. I’ll be ordering some here shortly.
    Sorry I never got back to you on that. Squeegie is right I didn't need anything additional just had to do some adjustments to other parts to get everything back to straight.
    Sep 2015
    S.E. Michigan
    1,482
    I have played with the current BL setup for long enough to want more torque. So I thought I would try another inexpensive option. I wanted the same basic size just without the fins and alittle higher Kv. I found this one at 4300kv for a similar price.
    https://www.banggood.com/Racerstar-3...r_warehouse=CN
    This one has a substantial increase to torque and top speed. I wasn't even able to hit speed without losing control on pavement using 23/55 gearing with 3s. Whole system was only warm to the touch as pictured. No fans or heatsinks with an outside temp of 84F. I really like this setup for now but I am getting a 20T pinion to slow her down alittle
    Sep 2015
    S.E. Michigan
    1,482
    I thought I would include the specs sheet that came with the motor and some calculations of the tested setup and what it will be with the 20T pinion. Cross your fingers, I hope it fits.
    (Right-click and open in a new tab if hard to read)
    Differential Ratio: 2.6
    Transmission Ratio: 1.9384615384615385
    Other Ratio: 1
    Spur Tooth Count: 55
    Pinion Tooth Count: 23
    Total Voltage: 12.00
    Motor KV: 4300
    Tire Diameter (inches): 3.62
    Tire Ballooning (inches): .20
    Motor Current Draw: 75
    Motor Coil Resistance: .0075
    Spur/Pinion Ratio: 2.39 : 1
    Total Ratio: 12.05217 : 1
    Tire Circumference (inches): 12.63 inches (320.78 mm)
    Rollout: 1.05:1
    Total Motor Speed: 49181.25 RPM
    Vehicle Speed: 48.8 mph (78.39 km/h)
    Effective KV Value: 4098.44
    KT constant: 0.31 oz-in/A
    Motor Torque: 0.12 ft-lbs
    Final Torque: 1.48 ft-lbs
    Final Power: 900 watts (1.2 HP)
    Other Ratio: 1
    Pinion Tooth Count: 20
    Motor KV: 4300
    Spur/Pinion Ratio: 2.75 : 1
    Total Ratio: 13.86 : 1
    Rollout: 0.91:1
    Vehicle Speed: 42.44 mph (68.17 km/h)
    Final Torque: 1.7 ft-lbs
    The first motor in the thread for comparison.
    Other Ratio: 1
    Motor KV: 3930
    Motor Current Draw: 68.3335
    Motor Coil Resistance: .0095
    Rollout: 1.05:1
    Total Motor Speed: 44608.77 RPM
    Vehicle Speed: 44.27 mph (71.11 km/h)
    Effective KV Value: 3717.4
    KT constant: 0.34 oz-in/A
    Final Power: 820 watts (1.1 HP)
    Yes I do my calculations with 4v cells because 4.2v doesn't last long in RL. I also do them with limited tire ballooning because I try not to drive on balloons
    Values exported from - https://scriptasylum.com/rc_speed/top_speed.html
    These are RAW values without things like wind resistance or road bumps so take them with a grain of salt.
    Sep 2015
    S.E. Michigan
    1,482
    I never did use the 20T pinion. It would of just increased the clicking I been getting from the rear diff. Now I guess I need the Hot Racing metal diff at least for the rear. Unless anyone else has another solution possible.
    17
    Quote Originally Posted by Jake483 View Post
    Same idea I came up with. It’s a shame the Sidewinders got slightly bigger. The old version fits perfectly between those tabs.
    Sep 2015
    S.E. Michigan
    1,482
    I been driving my MERV with this setup for a bit now and even toyed with using 2 batteries. I just zip-tied the ESC to the battery when I tried it. I have to say I found I liked it a lot better with just the single battery. The weight is much more balanced and I traction roll less. Using a 2s battery also slowed it down enough without changing the gearing but I am back to using the 3s mostly. Now that I am more use to the power and got my throttle control under control.
    Nov 2020
    3
    I installed the extended rear suspension arms and the front of both my tires are facing inwards by a lot. How did you adjust and straighten yours?
    RC Racer McCreary's Avatar
    Feb 2017
    NJ
    148
    Quote Originally Posted by Red13 View Post
    Page 24 of the owner's manual covers toe and camber adjustments.
    https://m.traxxas.com/sites/default/...-OM-EN-R04.pdf
    Nov 2020
    3
    Thank you very much!!!
    Feb 2017
    NJ
    148
    You're welcome.
    Traxxas makes adjustable aluminum toe links(part #7138). They make fine tuning the toe in/toe out a lot easier than the stock toe links.
