    Oct 2019
    What has my kid done ha?
    I have a 4 month old Slasher 4x4 ultimate that my 6 year has really bashed up, it is his though. However, today he had a pretty hard hit wide open against a curb and now I believe something is slipping. When I have pick it up, all four tires spin when pressing the throttle. However, if I push down on it slightly, then it sounds like the motor just spins up but tires do not move. If I move the throttle just a quarter of the way, then it will go, but full throttle it just winds up and barely moves. So it seems something starts to slip when either heavier weight is applied or revved up higher. Any thoughts?
    Jun 2019
    158
    Loose slipper clutch. Pull it out and tighten up the nut
    Dec 2016
    N Dakota USA
    461
    Quote Originally Posted by calebgilmore View Post
    Either the slipper clutch like he said above, or the pinion gear may be slipping on the shaft. I would check the slipper clutch first though.
    53
    Quote Originally Posted by Dakratfink View Post
    Agreed...on both accounts (slipper clutch or pinion)
    Sent from my iPad using Tapatalk Pro
