Results 1 to 29 of 29
    Nov 2014
    11
    upgrading esc only on 4x4 stampede
    okay so I can find many ESC motor combos. but what I'm wondering if I can just but an ESC to go with my Velineon motor for my stampede 4x4. I stopped playing with them for a few years and now getting back into the RC cars. I fixed one of my RC cars with transmissions issues but a few years ago. A puppy for whatever reason ate wires off my ESC, I guess metal tastes good I fixed re soldier and what not but there's a lot of heat build-up now with them and my 2S 5000mah doesn't last long at all in them compared to the 2wd stampede I have had both ESC motor fans on but 4wd just lasts about 4-6 minutes on one 2s lipo. but instead of buying another Traxxas one I wasn't sure if there are cheaper ones yet better ones out there. I have fried one of them with a Traxxas 3S lipo battery and vxl ESC since then I've never run a 3S in one since I went up in smoke but they are rated to 3s so doesn't make sense either. but it would also be nice to know I can use my 3s lipo battery also in the new one. can I just buy an ESC and no motor or would I have to buy both? I feel like its a dumb question but I have no idea if I can or what modifications need to be done. or is it just better-doing motor and ESC?
    Nov 2018
    Spokane, WA
    373
    Get a hobbywing max10sct
    Dec 2016
    N Dakota USA
    582
    Quote Originally Posted by Overpowerxmaxx View Post
    The one he suggested, or many other ESC will work with your Velineon motor .
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,175
    The Max10sct is considerably more than needed for a Stampede 4x4. You could use the Quicrun 10BL120 it is the equivalent to the stock Velineon esc but is programmable.
    https://www.amazon.com/dp/B0765Q2SVS...v_ov_lig_dp_it
    Nov 2014
    11
    I appreciate the reply’s. Now is the honbywing direct plug and play or would I need to soldier the connectors on it? I’d so what connectors are they?
    Oct 2016
    4,382
    Quote Originally Posted by Bow bow View Post
    It comes with bare wire, so you solder the connector of your choice. Makes sure the motor bullet connectors are the same size as well
    Somehow builds are never done....
    Nov 2014
    11
    I’ll see if I can find the connectors that the velineon motor has. Then look around for the hobbywing max10sct. Can only find motor and wax combo but I’ll look a little more later since I’m about to head to work.
    Sep 2015
    S.E. Michigan
    1,175
    Most 1/10th scale esc and motors use 4mm banana/bullet connectors but Velineon uses 3.5mm.
    Dec 2003
    Dekalb, IL
    2,503
    Just the esc for $85 on amain:
    https://www.amainhobbies.com/hobbywi...102601/p507477
    I run one in my stampede 4x4 vxl on 3S with a 3665 3100kv motor. It does ok.
    Expert rigging at it's best!
    Nov 2014
    11
    Would I need to programmer or anything for it too for that one?
    Sep 2015
    S.E. Michigan
    1,175
    The program cards for Hobbywing esc are optional. They can also be set manually.
    https://www.youtube.com/watch?v=XWq7pgAa6Cg
    Nov 2014
    11
    Alright thank you zedorda! I may go with the Max10 SCT ESC Combo with 3660SL 3200kV Sensorless Motor since it’s not that much more then the esc itself. I know my vxl motor gets pretty hot too so wouldn’t be a horrible idea unless this would get hot? Or would this motor not be good to use? I’m not exactly sure what KV means either
    Oct 2016
    4,382
    Kv is rpm’s per volt. This debate has been had many times. At the end of the day, and larger motor has to do less work to achieve the same goal. Kv selection really relates to what batteries you’re using. I personally run a 3660 can 2600kv on 3S and 4S. Runs super cool on 3S and is plenty fast geared 13/50. 4S is kind of insane to try and control. Tons of fun to try though.
    Nov 2014
    11
    I only run 2S since when I have ran 3s in the vxl setup the esc went up in smoke and never done 3s since so.
    Oct 2016
    4,382
    I wouldn’t let your past dictate your choices. The vxl esc is not good. The hobbywing will treat you with more hours of fun for sure, even on 3S plus.
    Nov 2014
    11
    Your right! that’s why I’m wanting something better for a little more money if that’s what I’ll have to pay. . I’ll go ahead and buy the esc tonight and 4mm bullet connectors for the vxl motor
    Nov 2014
    11
    Thank you all for the help I appreciate it I just ordered it!
    Nov 2014
    11
    Finally got the esc took a while to get it but everything is great soldiered the connectors programmed it. I broke an A-arm with the new esc, ran it into a tree while my dog was chasing it. but after running a few 2s 6400MAH batterys through it it’s a blast with it doesn’t arc like it did and got it cheaper then I could find the Traxxas esc gonna run the 3s in it soon and play around in the snow since were meant to get about 5 ish inches of snow on Wednesday so glad is alive and running, Thank you for the recommendation in this thread. I appreciate it!
    Oct 2016
    4,382
    Well done. Enjoy
    Dec 2019
    3
    Hi everyone,
    Sorry to jump into this conversation,
    If you could buy a VXL-3s for the sale price as the hobbywing, which one would you get?
    Cheers
    Sep 2015
    S.E. Michigan
    1,175
    Personally I don't replace stock with stock. I take the opportunity of breakage to upgrade. And imo the Traxxas esc work ok but don't have the flexibility/options I like. I have not tried a Hobbywing esc yet but I will soon.
    384
    I had overlooked the Hobbywing Max10 SCT ESC previously as I was mainly looking for a sensored ESC, but man, that thing looks good for the money.
    Seems to really outshine the Sidewinder 4... 4S Vs 3S (though only on low KV), but most notably for me an adjustable voltage BEC, which is nice as a lot of servos these days take higher voltages. 3A BEC on the HW vs 2A on the SW4 too.
    Still the SW4 coming in a combo with the 1415 2400KV motor is a really good deal. We’re spoilt for choice.
    Dec 2019
    3
    Quote Originally Posted by zedorda View Post
    So is there anything wrong with the VXL-3s? Also what are the benefits of aftermarket ones over this one.
    384
    More current carrying capability, PROGRAMABILITY, adjustable voltage BEC (and more powerful?), standard size motor bullet connectors (don’t try find the Traxxas 3.5mm compatible ones, if you’re going to resolder, do the motor ones and make them a standard 4mm).
    Most hobby shops will solder for you for a small fee when you purchase.
    Sep 2015
    S.E. Michigan
    1,175
    Quote Originally Posted by Noobie101 View Post
    boosta said it all really. Nothing wrong with the VXL-3s just limited.
    Dec 2003
    Dekalb, IL
    2,503
    The max10sct takes more abuse without overheating and as noted is more adjustable. I used to run the vxl-3s in my stampede, but changed to the castle sct sv3 then to the max10 sct. Now I'm thinking of running a lower kv motor than the 3665/3100kv I have as it still thermals on me when pushing it hard. Or my batteries died... Haven't sorted out which yet and likely won't until spring as the cooler temps of winter will mask an overheating issue somewhat if your right on the edge when it's 75F outside.
    Jan 2014
    Illinios
    26
    Is the max 10 sct that good. Trying to choose HW or mamba x.
    Dec 2003
    Dekalb, IL
    2,503
    Quote Originally Posted by freesteff View Post
    If you have the money for the MX, go that route. Is it worth twice the Max10 SCT, I can't say, but it is the better of the two.
    If it were me and I didn't mind spending a bit more, I'd like try to shoehorn in the 1/8th MMv2 or MMX (if I wanted logging/sensored) instead for more current capacity for a bit less than the 1/10th MX.
    384
    In the Mamba X price range there is also the Hobbywing XR8 SCT which is a nice ESC. I’ve heard team drivers racing it in 1/8 buggies and truggies.
