Results 1 to 13 of 13
    Sep 2019
    San Francisco CA
    73
    Brushless Motors
    Will reversing the two outside wires connecting the brushless motor to ESC, which makes the brushless motor turn in reverse, affects the performance of the motor in any way? I am installing a brushless motor in my TRX4, but the car runs on reverse rotation. Thanks!
    Oct 2015
    119
    Quote Originally Posted by TITANIUM94010 View Post
    If it's a sensorless motor, yes. If it's got a sensor wire, you have to make sure the A B C connections are matching.
    Sent from my Pixel 2 using Tapatalk
    RC Racer RC Dad's Avatar
    Jul 2019
    Boston
    206
    What motor and ESC? Sensored, non sensored? If is non sensored, you can move them around until you get the desired result.
    Sep 2019
    San Francisco CA
    73
    I am getting a motor with a sensor, so you're saying that if it has a sensor, I cannot make it run reverse?
    Oct 2015
    119
    If it's sensored, you will need to reverse it in the ESC options. What ESC & motor are you using?
    Jul 2019
    Boston
    206
    What motor? What ESC? Anything is possible. Everything is breakable.
    Sep 2019
    San Francisco CA
    73
    Motor: TEKIN ROC 412 HD, which is sensored and the ESC is the TEKIN RX4
    Jul 2019
    Boston
    206
    Should be clearly marked ďA B CĒ solder points on motor and ESC. donít mix those up.
    Sep 2019
    San Francisco CA
    73
    So I can switch A and C and still run sensored and in reverse rotation?
    Jul 2019
    Boston
    206
    https://www.teamtekin.com/manuals/tw...al_rx8gen2.pdf
    Sep 2019
    San Francisco CA
    73
    Ok, thanks,
    Somehow, I couldn't find the manual on their website, there were only manuals for the retired products.
    Jul 2019
    Boston
    206
    Ok, thanks,
    No problem. Pretty sure you can reverse the motor direction with your transmitter. Definitely donít want to move wires around while running sensored.
    Sep 2019
    San Francisco CA
    73
    Ok, thanks!
    I probably won't be running sensored because I'm going to be wading deep water.
    The floor is there to catch your RC, not break it
