    Oct 2019
    5
    Wheels and tires
    Hey everyone, I have a Blue Ford GT that's been upgraded a little bit.
    Motor and ESC: 6900Kv Castle Sidewinder 3/ESC combo
    Battery: 5000MaH 3s setup
    Wheels: Stock wheels with response tires
    The car is primarily used on asphalt, and since going to the 3s battery the car has no traction at all. I'm needing a recommendation on a wheel/tire combo or at least a set of rubber tires that will fit the stock 26/30mm wheels.
    I am also open to aftermarket wheels. As long as they are the same setup as stock or if you know of any hub extensions that will fit the 4tec 2.0 then a 26/26mm combo is fine. I have a set of aftermarket wheels for the car but running a 26mm wheel on the rear just looks goofy to me.
    Nov 2018
    Spokane, WA
    478
    26mm foam front
    30mm foam rear
    Get foams from contact
    These will give much more grip
    Oct 2019
    5
    How long would a 37 shore tire last?
    Nov 2018
    Spokane, WA
    478
    Depends on use speed runs would most likely last 2-8 runs depending on distance and how rough to asfalt is (how smooth is it-very used or freshly laid)
    Oct 2019
    5
    so i ordered a set of the 26mm/30mm rims/wheel combo and the hex (on the wheel was to big) does contact sell just the foam tires separately?
    Nov 2018
    Spokane, WA
    478
    What size is the hex
    Dec 2017
    North Texas
    631
    Quote Originally Posted by xLeGeNDx View Post
    It is hard to see but generally the tire is made of several doughnuts laminated together and smoothed to appear as one.
    The gluing process is not easy from what I hear. At the low cost of 1/10 foams it will be easier to just buy them.
