    Nov 2018
    58
    Narrow newer Rally for Speed Runs.
    Hey guys has anyone used a newer narrow Slash Rally for a speed run car?
    Nov 2018
    58
    I guess I will take that as a no....
    So I will tell you why. Because A) There are no good speed run bodies for it or any aftermarket bodies really. B) There are no steel driveshafts available for it. C) It comes with a plastic center prop shaft. I think those are the big reasons. Also its narrower...but I think no bodies is a big reason nobody does speed runs with the narrow rally. So if you want to do speed runs get a Slash with a low center of gravity chassis. Or better yet get a Limitless...
    470
    I donít know about bodies but I did see a short while ago MIP started making shafts for the 1/10 rally etc...
    https://www.miponline.com/19390-MIP-...iesta-ST-Rally
    https://www.miponline.com/MIP-X-Duty...s-Bandit-18390
    Maybe thereís a new model I havenít seen yet but I thought the rallyís had the same slash 4x4 LCG chassis? Just the narrower arms etc?
    If so you can replace the slipper and driveshaft with any compatible with the slash. You just need the front splined 6888X drive hub for the alloy shaft.
    Unless Iím totally mistaken? Not fully up on the rally variants.
