Results 1 to 9 of 9
    Oct 2019
    21
    Do i need to change gearing with 2.2 traxxas rustler tires on brushed 2wd slash?
    I just put rustler tires on my 2wd slash, it makes a really weird burning smell but no smoke, do i need to change gearing?
    Apr 2018
    942
    Check your slipper clutch. It may be loose.
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,126
    When it comes to gearing rim size really isn't what is important. The OD of the tire is. If you put larger wheels on that are taller than the originals you are changing the total gear ratio. If the wheel is taller you will need a small pinion or larger spur gear to get back to the original total ratio.
    I use this tool to help me figure my total gear ratio: https://scriptasylum.com/rc_speed/top_speed.html
    RC Champion Mr Wolf's Avatar
    Malmesbury, UK
    1,704
    Rustler tires are too wide to tuck under the Slash's wheel arches when the suspension compresses so maybe it's the smell of burning tire rubber due to rubbing on the body.
    Pretty please, with sugar on top, clean the RC car
    Oct 2019
    21
    I checked the body and ita not it, the motor smells like a cigar.
    Oct 2019
    21
    I will see if changes gearing will help
    Aug 2019
    Woodstock, Ga
    36
    I dont think the tires are the cause. Sounds like the motor got too hot. Usually dies soon after. Use compressed air to clean it and lube the bushings at each end of the motor. Maybe it'll last a little longer.
    Oct 2019
    21
    It was a fully hot
    Aug 2019
    Woodstock, Ga
    36
    Try going down teeth on the pinion gear. And consider drilling some 1/4 inch holes in the windshield. A transmission case with an aluminum mounting plate makes a huge difference in cooling. RPM or HR racing makes some.
