Thread: Wheel Base help
    Oct 2019
    Wheel Base help
    I have recently picked up a 4 tec 2.0 and need a about inch longer wheel base if I can to fit a body I picked up for it( if nothing else I can mod the body some). I know I can move the rear back 3mm. Has anyone moved it more? Maybe a mod, different control arms or anything? Any help or ideas would be great.
    Oct 2018
    37
    I don't know... You'd probably need a custom carbon fiber chassis and a longer driveshaft made. Or cut the stock chassis across the middle, extend and mend. Still need a driveshaft though.
    Sent from my VS987 using Tapatalk
    RC Champion RCWilly's Avatar
    Feb 2019
    California Bay Area
    1,176
    Although I have never done it to mine, I have found instructions on how to do so on page 26 of the owner's manual.
    Online manual link: https://traxxas.com/sites/default/fi...-OM-EN-R01.pdf
    Here's what it says (there is a picture on the manual about it)
    "The 4-Tec 2.0 chassis allows you to lengthen or shorten the
    wheelbase by up to 3mm for the perfect body fit. Remove the rear
    suspension arms from the vehicle and trim material from the front
    or rear of the arms. Save the material you remove and add it to the
    opposite side of the arms to act as a spacer, or use washers to shim
    the arms. Note: The front suspension arms are not adjustable and
    should not be modified or trimmed." (Page 26)
    Hope this helps!
