Results 1 to 15 of 15
Thread: Rustler VXL
    Apr 2017
    Rustler VXL
    I am kind of new to rc cars right now I have the electric Rustler, I was wondering what upgrades I should make to it. And I was also wondering how the Rustler VXL is compared to the regular Rustler. And how fast and good is the rustler vxl stock?
    RC Turnbuckle Jr. jvogel's Avatar
    Oct 2010
    PM me if you want to bash near Grass Valley, CA
    3,144
    I love my Rustler (Rusty). You have the brushed, Titan/XL-5 powerplant, right?
    A brushless system like the Velineon/VXL-3S system is far superior. I happen to really like the offerings from Castle Creations.
    Like this combo:
    https://www.amainhobbies.com/castle-...115-05/p618576
    Check out the Castle Creations website and drool.
    Also, switching to LiPo batteries is fantastic. Worth every penny. I like SMC packs but Traxxas has a charger with two LiPo packs for $200. It's a pretty good deal.
    https://www.amainhobbies.com/traxxas...ra2990/p474595
    Obstacle Magnet
    Apr 2017
    What would be good upgrades to make to my electric Rusler (aluminum/RPM plastic parts)? I broke the rear axle carriers 3 times..... barely even hit a bump. But I was also wondering if I make some of the parts aluminum obviously it's going to add wait so should I put a better/bigger motor on it a better battery and a better speed control? If so what ones should I put on it?
    Oct 2016
    4,395
    An important difference is the VXL has bearings where the XL-5 has bushings. I believe the tranny is different, the tie rod ends are not adjustable with the XL-5. Really the difference between the two is night and day. I think as. Starter vehicle most would prefer to buy the VXL and put the esc in training mode. That being said many people buy and enjoy the XL-5
    Oct 2010
    3,144
    Don't go aluminum. Plastic is cheap and a good weak point. Why break worse things? Replacing a chassis is a lot more work!
    Obstacle Magnet
    Oct 2016
    4,395
    For castor blocks and axle carriers is go with aluminum, unless you're just off-road bashing. I was on and off road prior to my cars transformation. I had a good mixture of aluminum and rpm parts. Those king pin in the castor blocks, with plastic bend like its there job
    Oct 2010
    3,144
    Gripdog7205 is absolutely right about using aluminum castor blocks. This is a must. Plastic castor blocks flex which causes the kingpins to become bent and thus, ruin steering performance. Your kingpins may already be bent.
    Gripdog7205 is also right about replacing the bushings with bearings. That is a fantastic improvement too.
    Obstacle Magnet
    Oct 2016
    4,395
    Both of these upgrades are cheap and easy as well.
    RC Qualifier Myrustlervxl's Avatar
    Dec 2016
    Ohio
    500
    I will vouch for aluminum castor block. the king pins do bend like play doh with plastic castor blocks, and they look cool. I have the vxl so it has ball bearings.
    Sent from my SM-G930P using Tapatalk
    Good work isn't cheap, cheap work isn't good
    RC Champion NYbandit33's Avatar
    NY
    1,153
    What are your plans for the vehicle? On or off road bashing? Are you interested in run time? Speed? All of the above? If you have an XL5 and youre not satisfied, I would look for a used VXL esc/motor and upgrade the bearings and see how you like it. Upgrading any item you continuosly break to aluminum might not be a bad idea but the castors and hubs should really be all you need
    May 2007
    Endicott, NY
    743
    Looking for a way to widen the rear of a Rustler without mods and effecting the suspension geometry.
    The web suggests running front wheels all around. I looked at RPM's site but do not see anything about longer rear arms. There are a ton of mods on the web to widen the front but little on the rear.
    Thanks
    trinity 6cell packs - 5 cells for the price of 6!
    Jan 2019
    [Typewriter noises] . . . Somewhere in the Eastwest . . .
    200
    The reason for this is that the front of the car is narrower than the rear. If you widen the front and then use wider wheels all around, the car is wider overall. Any change you make to to anything attached to your A-arms will affect suspension geometry.
    Oct 2016
    4,395
    Quote Originally Posted by Kenmtb View Post
    Thanks
    I run all rears. The. Got 10mm offset hubs for the front. I only did this after switching to closed wheel body. In open wheel format itís really hard to tell the difference
    May 2007
    Endicott, NY
    743
    Interesting points. I was hoping that there was a simple way to get a similar wheelbase as a T6.1.
    It looks like the way to go is play with wheel offsets and spacers. I would be nice if there were arms that were extended on the ends only.
    Oct 2016
    4,395
    You can get the proline kit but then your replacing tie rods and camber ends
