Results 1 to 25 of 25
    Jan 2018
    67
    Rustler/Bandit Mid Motor Laydown Conversion
    Hey everyone! I wanted to share a new project I've been working on. It's based on the Slash conversion I did last year but it's got some improvements based on things I learned on that last project.
    This time around I wanted to make something for the Rustler/Bandit platform. Stadium trucks are my first RC love and buggies are where it's at in the racing scene so it made perfect sense to see what I could do with this platform.
    There were a couple of things about my Slash conversion I really didn't like. The L braces I used to mount the top brace to the chassis were a pain in the rear to manufacture and they let the car flex a bit too much up front. This time around I'm ditching them in favor of some beefy aluminum stand-offs that I can just buy right off of mcmaster-carr. I've also tweaked the side stiffeners so they are more "in-line" with the top brace.
    The next major issue I wanted to address was getting the transmission case back in it's stock location. I had to move the transmission case 1/2" forward on the Slash to prevent the spur gear from interfering with the shock tower. It mostly worked, though I still had to modify the shock tower, but it also put the drive shafts at a pretty extreme angle which I just didn't like. My solution this time was to ditch the stock shock tower and redesign it so it's narrower at the base. I also designed a camber mounting plate that puts the camber links further back and prevents them from interfering with anything.
    I've been working on this project for a few weeks already but I just machined the new chassis parts today. Check it out, it's already looking awesome!
    My biggest decision I still need to make is if I should turn it into a Rustler or a Bandit. I love stadium trucks, but I'd also want to take a buggy to my local astroturf track to race. hmmm....
    Dec 2016
    N Dakota USA
    591
    I was looking at this earlier. Impressive prototyping.
    Can’t wait to see more
    RC Qualifier FlyingTigerDad's Avatar
    Jan 2016
    SoCal
    609
    I enjoyed the Slash build that you did earlier quite a bit, so I'm definitely looking forward to seeing how this turns out. Your engineering/fabrication skills are top notch, and these builds come out very professional looking. The Slash was an excellent performer as recall too.
    I'm sure you'll get the kinks worked out, and any weaknesses you perceive corrected for another quality build. And as much as I'd like to see this come out as a stadium truck (they're kind of my thing too), I do think you'll probably get much more use out of it as buggy. It's just (unfortunately for guys like me) a much more popular racing class.
    Knowledge gained is lost forever if not passed on.
    Jan 2018
    67
    Done!
    I had the day off so I used it to machine the rest of the parts for this build and swap everything over from my slash.
    I decided to make a rustler out of this build mainly because I just didn't want to have to buy new arms/links/drive shaft. The only thing I really need now is some ST wheels/tires and a rustler body. For body I'm thinking the jconcepts f150 because it reminds me so much of my old T3. Speaking of the old T3, I borrowed the body to get an idea of how it's going to look finished!
    Under the body - the electronics are jammed in pretty tight up front but they just barely fit.
    This new transmission case design puts the drive shafts back in line with the arms.
    Custom camber link plate
    And my favorite part - NO MORE HARD TO MAKE L-BRACES!
    While putting this together I wrote down everything that was "wrong" - things like bearing fitment inside the transmission being too tight or moving hole placements and diameters on the chassis. Unfortunately there were issues from the previous design that I never wrote down or fixed.
    I've also got a few ideas for things I want to change. The shock tower definitely should be made out of something thicker/stiffer and the shape needs to be tweaked a bit as well.
    Overall I'm pretty pleased with this design. The place that does the 3d printing had a new minimum order price that they didn't have last year so I ended up ordering three of the transmissions cases so I'm thinking I may still end up building myself a bandit
    Jan 2016
    SoCal
    609
    As I suspected - another fine job. The truck looks great and I imagine will be a great performer as well, especially with some of the design improvements you mentioned (drive shafts in-line with the arms, etc.). Glad you went with the stadium truck setup. I like the JConcepts F-150 idea for the body too, it will look great on there - very T3 like indeed. Looking forward to a track report
    Jan 2018
    67
    Thanks FTD! I'm more excited about getting this on the track than I ever was about my Slash. Stadium trucks just drive so much better than SCTs and I can't wait to see what this can do.
    When I raced my slash I really got a kick out of driving the pink RTR body. It's just not what you'd expect to see on a car setting fast laps. I think the JC F-150 gives the rustler that old school 90's look that would be equally unexpected - it would be the next best thing to the original rustler body which is what I'd absolutely love to have.
    Jan 2018
    67
    Alright, so I just pulled the trigger on the JC F-150 body. I'm excited for that to get here... not so excited to paint it.
    Anyway, I was moving around some stuff in my RC area and stumbled on my old 22 3.0 chassis. I thought it would be interesting to do a quick comparison between a (nearly) modern race chassis and my rustler.
    This first shot shows the 22 3.0 in it's original mid motor configuration with the battery the whole way back. The battery and motor are much farther back on the 22 than the rustler.
    While it wasn't originally an option on the car, there were aftermarket laydown kits you could get for the 22 3.0. The picture below shows where the battery and motor would have been in that configuration. It's pretty interesting to see that it's just about right in line with my rustler design.
    Anyway, I never realized how drastic the difference was between a regular mid motor configuration and a laydown configuration. The laydown puts the two heaviest parts an inch closer to the center of the car which should drastically reduce it's moment of inertia when turning.
    On a final note, I took the car out for a quick bash session in front of the house. It drives so much better as a stadium truck even just bashing around on the street. I can't wait to hit the track with it!
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,175
    How does it compare in weight to an original rustler?
    Jan 2018
    67
    I don't know how it compares to a stock rustler, but I did weigh it last night.
    The total weight with the T3 body, SCT wheels, and the electronics you see in my pics was 1790g with a 45:55 front:rear weight distribution.
    Sep 2015
    S.E. Michigan
    1,175
    Stock VXL 2wd Rustler without a battery is 1,690g. In case you were wondering.
    Jan 2018
    67
    Good to know! In that case my truck is lighter than stock by a good margin. My shorty pack is 215g which takes my truck down to 1575 without a battery. That's 115g less than stock!
    Sep 2015
    S.E. Michigan
    1,175
    By the looks of it you could if you wanted still shave off another 100g or more. But seems like a screamer already.
    Jan 2018
    67
    The JConcepts F-150 body is all painted and ready to go. At this point it looks too darn nice to even think about running it. I just need to figure out a way to rig up a body post for the rear and it's good to go. I thought the body would be narrow enough to Velcro to the side of the chassis but unfortunately that's not the case so now I need to improvise.
    Jan 2016
    SoCal
    609
    The F-150 body came out nice & clean - it looks great! Ready to hit the track! Perhaps an Associated, or Losi rear truck body mount that attaches to the shock tower might work well. I'm sure you'll come up with something good & secure. Good luck & keep us posted on it's track performance. Will you be installing a sway bar setup at all?
    Jan 2018
    67
    I figured out a less than elegant solution to the rear body post.
    And finally, here it is completely track ready (except the SCT wheels/tires, but it's close enough at this point to try it at the track).
    Jan 2016
    SoCal
    609
    Quote Originally Posted by rc10nick View Post
    A good sturdy solution, even if not the most elegant - it works. Good luck on the track - I really want to see this truck do well.
    Jan 2018
    67
    I got the car out on the track today! Unfortunately I didn't take any time to set it up so it drove like a dog. The biggest problem was how bouncy the thing was. Every time the car landed it would bounce around wildly. I'll need to address that before I take it out again. I also need to get a set of proper turf tires - my SCT mini pins just won't cut it.
    I only got about a pack and a half in before my rear shock tower broke. Going in I knew if anything was going to break it would be either the rear camber plate or the shock tower so I'm not entirely surprised. I used the same 3/32" G10 for the shock tower that I used for the chassis when really I should have used something thicker. I'll be getting a sheet of something thicker for the next one. I'll also machine in a body post so I don't have to have that ugly chopped up stock tower bolted to it.
    Jan 2018
    67
    I was getting ready to post an update pic with the new turf wheels/tires I bought when I noticed something - take a look at post #15 above. Notice anything in the first picture? One of the hex screws holding the tower into the transmission case stripped out when I did the test fit of all the new parts. I tried using my hacksaw to put a slot in the screw head (I was out of cut off wheels for the dremel so I improvised), but as you can see I ended up cutting into the shock tower instead. That's exactly where it broke - now I'm wondering if the shock tower would have been fine if I hadn't damaged it with the hacksaw. Something to think about...
    I still haven't gotten the thicker g10/fr4 in the mail yet, but I ran out to my LHS today to grab some turf tires for the truck. I got them mounted up this evening and they look pretty nice.
    May 2017
    47
    Fantastic
    Great build! I just did my first race in a 13.5 stock stadium truck class with my Rustler. Lets just say that I had my butt handed to me. Fastest lap to fastest lap I was at about a 2 second deficit. I'm sure my driving wasn't up to par, but overall I didn't have the handling to even hang onto the tail of the pack.
    Now onto your 3D printing stuff. I'd love to work with you on this. I do structural 3D printing and CAD design as a side business. I print in carbon fiber reinforced nylon and I'd really like to work with you on your gearbox.
    I plan to develop a few parts to make my Rustler a little more competitive as well. I had intended on getting a Losi or Associated, however I'm going to tinker a little more before giving up on the Rustler.
    Thanks,
    Andy
    Jan 2018
    67
    Thanks for the kind words! It's nice to hear from a pro that I'm not completely off track!
    As far as the design work goes I'm pretty much done. Everything at this point is error correction and refinement. I really don't have any further "big changes" in line for this project.
    I've got some more updates since my last post. I got the thicker g10/fr4 in the mail on Tuesday so when I got home from work that day I spent the evening cutting out new parts and working on the shocks.
    Here's the new thicker shock tower in black g10/fr4:
    I was a bit skeptical at first about the look of the black g10. This stuff is fairly glossy and I prefer a matte look, but once I cut parts out of it I realized it looked fine.
    I made two shock towers and two camber plates to I could have spares just in case I broke something again.
    You can also see in the picture part of what I did with the truck's setup. I took out about 6mm of droop all around and snapped this picture between doing the rear shocks so you could see how much that really is. I also lowered the ride height as much as I could.
    Last night was another practice night at the turf track. Between the new tires and the tuning I did to the truck I was able to shave an entire second off of my fast lap time - from 18.6 down to 17.6. Those lap times are competitive in stadium truck at that track but not the fastest. The real fast guys can get down into the 16s at that track with a truck. However, even at my peak when I was racing every weekend these guys were still a fair bit faster than me even when I was running modern high end kits so I'd say the gap in lap times are about equal to the talent gap that existed in the past.
    I do think I can gain more time through set up - the fast truck guys were all running sway bars so I'm going to have to add them to this car similar to how I did them on my previous build. The challenge will be adding a front sway-bar. The RPM arms don't have any extra holes for mounting sway bars so I'm going to have to get pretty creative.
    Finally, I wasn't able to run the truck the entire night. This time the steering bell crank on the truck broke. While it's at least validating that nothing I made broke, it's still frustrating when other parts break and end my night. This track isn't connected to a hobby shop and I don't have spare traxxas parts so anything that breaks pretty much ends my night.
    Jan 2018
    67
    Time for another quick update!
    I replaced my broken steering bellcrank with the black aluminum Hot Racing bellcrank. I thought about just getting another stock bellcrank, but I run a metal gear servo with no servo saver. If I bought another stock part it would likely break again. The HR bellcrank also has the benefit of being much more precise - there is far less slop in the steering now as compared to the stock bellcrank assembly.
    I also got to thinking about how I have adjustable camber link locations in the rear, but nothing for up front. I realized I was more than capable of addressing this issue and went to work designing and making my own front shock tower with maybe way too many camber link holes. Right now I have the front links installed in the spot that lines up with the original stock tower.
    Jan 2016
    SoCal
    609
    I saw the nick (pun intended ) in the old rear shock tower, but wasn't sure if it was a shadow in the picture, a flaw in the fiberglass, or an actual cut in the material. Either way, the thicker black G-10 tower you came up with should work well as a long term solution (like the integrated rear body mount too).
    You should have pretty good luck with the HR steering rack as well. My son's 2WD Slash has that setup, and it's quite resilient.
    The front tower is a nice addition, but I agree with you, and think you may have gone a little overboard with Swiss cheese camber link mounting selections - about half those choices should cover just about any track condition setup.
    Very nice truck though, and yes, sway bars will get it absolutely planted on the carpet.
    Jan 2018
    67
    Well, it turns out the swiss cheese shock tower was a bit over the top. In less than a couple laps on the track last night I managed to break the shock tower. It wasn't a big deal because I had the original tower with me just in case. I threw that back on and got back out on the track.
    The new shock tower felt better on the track - before heading out last night I lowered the front link so it matched what I had in the rear. The car felt like it responded a bit quicker.
    Unfortunately the night still ended early when I snapped one of the stock steering blocks! Ugh, this is getting frustrating!!! I'm 0/3 on surviving an entire practice night and 2/3 breakages were stock traxxas parts. There's no on-site hobby shop at this track so any breakage ends my night. I guess I need to start carrying spares. I give myself a monthly "fun money" budget and this car is really burning through that money at a fast pace I might just take a break until new years when I get my next transfer into my fun money bank account. Either that or I have to find something to sell.
    On a positive note I re-tuned my shock oils and pistons. The piston holes I was using were way too small. With heavier oils the shocks were locking up and causing the truck to bounce off of the wheels. Lighter oils causes the chassis to slap. There was no middle ground between bouncing or slapping so I had to change the pistons. I drilled them out to make them bigger and went up to a heavier oil. It made a huge difference on the track. The car was so much more stable with the heavier oil and landed jumps much better. I don't think I was any faster than the last time I was there. My hot lap before I broke out was a 17.5 which is about the same as last time I was at the track, but the difference was in the lap to lap consistency. I was certainly averaging faster laps.
    Jan 2018
    67
    By some miracle I found some money sitting around in my paypal account I had completely forgot about. I decided to use that money to order a set of RPM front spindles and the Hot Racing set of aluminum caster blocks (my guess is the caster blocks would have been the next to break so I just wanted to get out in front of that). I got those installed on the car and went out to the track for another practice run.
    This time around I managed to make the entire day at practice before breaking anything! Something inside the transmission broke this time around - the layshaft spins but the wheels don't. I'm thinking I sheared the drive pin on the layshaft. It's not the first time I've done that with this car. I also popped off a shock cap twice but that was able to screw back on both times.
    The car drives pretty nice for the most part - I still have issues with the shocks being too bouncy. I'll need to adjust the pistons/oils some more but that's a straightforward process. Since I was able to go a whole day of practice without breaking until the very end I was able to really concentrate on improving my lap times. My previous hot lap was 17.5, I've now brought it down to 17.1. I was almost able to keep up with the guy who regularly wins the truck class at the track. I think with just a bit more setup tweaking I can break into the 16s and really be competitive.
    Finally, for Christmas I got the Hot Racing diff and the STRC layshaft. Now that I have to open up the transmission again to find out what's wrong it will be the perfect opportunity to get these new parts installed.
    Jan 2016
    SoCal
    609
    Sounds like some good progress. The pieces you have coming will certainly add some strength and performance to your setup, which should help you break that 17 second mark. I look forward to seeing this truck in action.
