Results 1 to 10 of 10
    Oct 2019
    Dirt track to drag racer
    I race dirt track all week and on the weekend I want to drag race with another group. I bought a JC Lightning body problem is it is only 11 inches wide the Slash is 11.65 . I need tire wheel combination with offset that will narrow it . I bought a used Slash one time that had a narrower track , it kept on flipping over every corner, when I compared it to my buddys we found out it was way narrower. Those tire wheels are long gone. I know I could change the a arms to Bandit arm but I don't want to have to do that every weekend. I want some street tires wheels that will narrow it up for straight line running. Any ideas?? Thanks
    Apr 2015
    782
    Put 0 offset scte wheels on it. Those are the narrowest wheels available
    Jun 2014
    Southern California
    7,574
    People have used parts from the Bandit to narrow the track width of their Slash 2WD. Not sure how much of the swap translates to the Slash 4WD.
    Edit:
    Read the description on Proline's website for tips:
    https://www.prolineracing.com/bodies...clear-body.asp
    Also done by JConcepts on the 2WD Slash:
    http://www.jconcepts.net/garage/proj...inator-concept
    Hope you can get it to work for your 4WD.
    Good luck!
    Nov 2019
    Have you heard of anyone having issues after that swap, Squeegie?
    Jun 2014
    Southern California
    7,574
    Hello and welcome to the Traxxas forums!
    I have not heard of anyone having problems with it from a 2WD Slash. I don't know about a 4WD swap.
    Here's more info on the 2WD "Slagster" conversion:
    https://traxxas.com/news/custom-drag-slash
    Have fun!
    Edit:
    I just watched the video and they turned the ESC on before the transmitter!
    Aug 2015
    470
    This info might be in the links above. The only "drag" car body that fits the 4x4 is the Pro-Line Octane. All the others are meant to be used with the Bandit arms, links and axles on a 2wd.
    Aug 2015
    470
    I haven't tried using the "Octane" body on a standard width 2wd but I suppose it would work. Is that body supposed to resemble a Camaro? It almost looks like a Duster/Dart in some photos.
    Jun 2014
    Southern California
    7,574
    Not sure what the offsets of the Pomona Drag Spec wheels/tires are, but they look good on the wider Octane body. Too bad it is wider than the JConcepts body.
    Too bad Pro-Line discontinued the wheels they used for their ProTrac system... but I don't think they would have narrowed your track width enough anyways.
    Good luck.
    Oct 2019
    Well I took measurements on the slash today, end of axles come out 10.75 so 0 offset SCT wheels may work out. If that doesn't work I will get a 2 wd slash and change it over to bandit parts. I travel in an rv all winter so my hobby shop is the trunk of the car I tow, kinda short on room.
    Apr 2015
    782
    Check this out. This may help a little.
    https://youtu.be/ijcsdsK3IUg
