So... Brand new Maxx. After a few hours, one of the fan broke2 of the wings were missing. After reading about the problem, both broken wings on the fans and overheating problems i decided to get a better fan as the sound of the original was also driving my crazy. Just listen to the difference
After replacing the fan on the ESC i ordered one for the motor too.
I think the original fan is around 3 cfm, the noctua is 9,4 cfm
The one i used: Noctua NF-A4x20 5V Fits exactly on top of the heatsink with 4mm screws. All you need to do is the replace the connector.
Hmm, insert image wonīt work... So here is the link
https://imgur.com/a/fyVVpss
Thanks for the heads up that fan fits mate. Keep us posted on the result of installing one in the motor shroud as well!
Will doThe fans should have arrived today, but the carrier delivered it to the wrong place
And btw, i don't question if the aluminum fan works. Seems like quality. For me, it is cfm and definitely also the noise. I see the aluminum fan running at 28k rpm. After all, itīs RC cars not RC planes![]()
Got the other fan today and this is how it looks:
https://imgur.com/a/uRfVBF2
Again: 4mm screws (iīll get new ones in stainless steel later) and it sits perfectly stable. I can lift the car in the fan. The Maxx is very quite now but still they move alot of air.
So if others are also annoyed at both the quality of the fans and the sound level, then this might be a solution![]()
Nice work bolting directly to the heat sink!
Thanks for sharing, good to know replacement parts that work!
